Author Topic: Maj .Edward Mannock's S.E.5a question  (Read 3551 times)
Offline Red Leader
« on: December 06, 2012, 05:32:02 AM »
Does anybody know if Mannock's S.E.5a was tail number E.1295 or D.278.  Was the individual letter "A" on the top surface of the wings and not only on the sides of the fuselage?  And was it a two-blade to four-blade propeller?
Any help is appreciated.
Esteban
RedLeaderModels.com
Re: Maj .Edward Mannock's S.E.5a question
« Reply #1 on: December 06, 2012, 07:51:19 AM »
The Osprey SE5a Aces Book states that D278 "A" was his most common airframe on 74 Sqn where he scored 36 victories in less then 9 weeks. Their profile shows a 2 blade prop, no info on the "A" on the upper wing. I have another reference which states it as D276 "A" but I believe that to be in error.
I also had a quick look at my SE5/5a Squadrons Book from Albatros, no answers there either.
These are for his time as A Flight Commander on 74 Sqn, I don't have any info on his aircraft when he was CO 85 Sqn where he died in combat.
Hope this is of some help.
Offline Red Leader
« Reply #2 on: December 06, 2012, 08:12:14 AM »
Great thanks for the reply.  The 1/48 Roden kit shows that Mannock flew E.1295 with 85 Sqn.  The aerodrome.com also shows he recorded 9 victories while flying this aircraft.
I guess I have two options to build for the WNW S.E.5a.
Thanks for your help.
Esteban
RedLeaderModels.com
Offline rowan broadbent
« Reply #3 on: December 06, 2012, 08:38:03 AM »
Sorry Esteban, but the two aircraft of Mannock's you mention were Viper engined - so the WNW Hisso-powered kit would not be right. There is the Roden Viper kit though - not too bad but by no means a Wingnut kit.
Forget your perfect offering
Leonard Cohen
Offline Red Leader
« Reply #4 on: December 06, 2012, 08:39:56 AM »
It is possible to make adjustments to replicate a Wolseley Viper engine on the WNW's kit?  What were the differences?
Many thanks,
Esteban
RedLeaderModels.com
« Reply #5 on: December 06, 2012, 08:56:55 AM »
Actually the modifications to the engine are limited to adding a gearing housing at the front. The major differences are to the radiator area and upper engine cowling panels. I'm sure a little research can provide fuller details. I don't think that it would be quite as easy to do as might be thought at first glance - particularly in 32nd scale. Interestingly, since the WNW kit was released in 2009 I don't recall anyone posting an on-line build of such a conversion. Still scope there for someone to do a resin conversion..........
« Last Edit: December 06, 2012, 09:10:42 AM by rowan broadbent »
Leonard Cohen
« Reply #6 on: December 06, 2012, 12:18:56 PM »
Rowan,
    DOOOOOOOOH! I completely missed the obvious on my reply, Thanks and I'll be a little more thorough in future. There's "experten"  and then there's oldsters like me who "sort of remember or think they recall a definite statement from before................"
   Does highlite the need for (mentioned yesterday by another member) a Viper SE5a in 1:32.
Offline Red Leader
« Reply #7 on: December 06, 2012, 07:22:11 PM »
Thank you for replies gentlemen.
Esteban
RedLeaderModels.com
« Reply #8 on: December 06, 2012, 09:45:35 PM »
Hello All
Just to add to the discussion..... I haven't had chance to check through any back copies of Windsock, but I've just taken Franks and Saunders' 2008 work, Mannock: The Life and Death of Major Edward Mannock VC, DSO, MC, RAF off the bookshelf.  In Chapter Nine, 'Commanding 85  Squadron', pages 130-2 include the following passage
"Once he had settled in, Mannock chose SE5a E1295 with a 200 h.p. Wolsey Viper engine. It had been brought from No. 1 Air Issues Depot (AID) on 20 June 1918 and while it had been worked on by the mechanics to bring it up to 85's standard, it had only been test flown thus far and not operationally. Mannock would fly this machine for the whole of his short time with the Squadron. As far as we can tell, no photograph of this machine has ever been seen so its markings are unknown, other than it no doubt had the white hexagon that identified 85 Squadron, on the fuselage sides aft of the roundel... Horn, who had done so much to hold the Squadron together during Bishop's period and while awaiting Mannock's arrival  .....  had taken over Bishop's SE5, No C1904, and flew it for the rest of his time on the Squadron. This machine was declared unfit for further service by late September .....  It had been marked with the letter "Z" painted both beneath the cockpit and on the upper starboard wing. One has to wonder if Mannock used the letter 'Z' on his machine too, and that Horn's C1904 was re-marked with the letter 'A', so as to denote the leader of A Flight ..... Letters after R would go to spare machines (at least one squadron used 'S' for its CO) ..."
In the same text there is a copy of a familiar enough photo captioned as showing a line up of 85 Squadron's SE5s just prior to Mannock's arrival as CO. In the foreground is C1904, with the upper wing 'Z' just visible. The prop is visible but my poor old eyes can't quite tell whether it has four blades.
Offline Red Leader
« Reply #9 on: December 07, 2012, 05:21:09 AM »
Thats great thanks Nigel for sharing that info.
Esteban
RedLeaderModels.com
Offline kornbeef
« Reply #10 on: December 07, 2012, 06:47:06 AM »
Mastercasters do/did a replacement Rad for the SE5a (Roden) its really nice and would save some mods though I imagine on of the PE vendors have it pretty much covered too.
