Author Topic: Dual Build: CSM Nieuport XXIII & Roden Pfalz DIII 1/32nd scale  (Read 63633 times)
« Reply #75 on: September 24, 2020, 12:36:30 AM »
Lovely work, Rick!
Seeing the Pfalz brings back fond memories.
Good luck!
vB  ;)
Thanks Bob. Glad you  are looking back Fondly to your beautiful build!
I see you are taking a pragmatic approach with the level of engine detail and the machine guns - smart!  Better to get this done than get bogged down in details that won't matter.
Yes, not seen, Not Modelled  8) I will add some wiring/piping along with the control wires. Still have to install the panels for the magnito and the control grip and triggers on the stick.
« Reply #76 on: September 24, 2020, 08:59:35 AM »
Todays progress:
Offline smperry
« Reply #77 on: September 24, 2020, 09:09:48 AM »
Looking god Rick. Smart move to model only what can be seen.
sp
« Reply #78 on: September 24, 2020, 09:20:58 AM »
Most excellent work on the Pfalz pit Rick . Nice shade on the fuselage inside walls and frame work as well  :)
« Reply #79 on: September 24, 2020, 10:45:34 PM »
sp
Thanks SP. It is a decent kit and will look good with just a few visible details added. It could be made great by going crazy building new frame work and opening panels but that is not My Mission  ;D
Thanks Terri! I am pleased so far  ::)
« Reply #80 on: September 25, 2020, 08:22:57 AM »
The final details have been added to the interior. The fuselage , lower wing, and tail plane are assembled bringing this one more or less in line with the Nieuport 23.
« Reply #81 on: September 25, 2020, 11:34:24 AM »
Your Pfalz is shaping up wonderfully Rick  :)
 How was the fit of the lower wing ?
« Reply #82 on: September 25, 2020, 01:39:19 PM »
Thanks Terri. The lower wing took some tweaking and will require a little putty and sanding. Nothing near your Triplane build though  8)
« Reply #83 on: September 25, 2020, 11:10:59 PM »
Coming together well, Rick.
Will you be adding the walk-way on the port wing? How about the seam tape along the spine of the fuselage?
vB
Offline petrov27
« Reply #84 on: September 26, 2020, 12:29:21 AM »
These are looking fantastic!
Any chance you would part with the 2nd/alternate cowl from the N17 kit? The one with the joins on each side instead of the top?
-Patrick
« Reply #85 on: September 26, 2020, 12:32:51 AM »
vB
Thanks Bob. I will certainly add the seam tapes like I did on My DIIIa kits. I will have to find a good photo of the walkway and then probably will add it to the Pfalz.
Absolutely Yes Patrick. I think I have more than one anyway and it is of No use sitting in My Spare parts box  ;D
« Reply #86 on: September 26, 2020, 01:26:56 AM »
You do set a pace when building models Rick. I am glad that I am not in a race with you - you would win every time. In spite of speed there is no drop in the standard of your models. Bravo!
« Reply #87 on: September 26, 2020, 09:06:17 AM »
I don't think they ever will be another one like that .  ;)
Offline Old Man
« Reply #88 on: September 27, 2020, 06:42:17 AM »
Nice work indeed, Sir.
"Not seen, not modeled," is an excellent motto.
« Reply #89 on: September 27, 2020, 07:55:16 AM »
Thanks Stephen. It may not be a Mike Norris build but I am Happy so far  8)
Thanks for the positive comment Old Man !
