Author Topic: SPAD XIII 1/33rd Papercard Model by Luis P. Igualada  (Read 4865 times)
Offline NinetythirdLiberator
« on: July 12, 2020, 03:39:49 PM »
All,
Here is a paper model that is sort of the WNWs of paper models.  It fit so well and was designed to a "T".  Superb coloring, lovely fit, extreme fidelity to the real machine and innovative construction all combine to make a really nice, detailed rendition of the ol' SPAD.  You should see the cockpit...dang thing even has a camera in there!
My only construction changes were, as usual, using 1/32nd balsa instead of cardboard for the structural members and I also used thin wire for the interplanes rather than interior cardboard/wood as was called for.  In addition, I did some post shading via airbrushing with a very dilute mix of acrylics in isopropanol of a black/brown mix for some additional depth, grime, underside dirt and demarcations of control surfaces.  I also added some more exhaust weathering and some soot along the gun troughs (probably a bit overdone).
Additions include a photo-etch gun site and gun site bar, thin plastic sprue aileron links on the bottom wing, aileron torque tubes along the rear outermost strut, EZ-Line rigging and hand-lift straps on the rear fuselage sides.  I also opened up most of the louvers and added a fuel line under the top mid wing section.  Oh!  And I added some brass and pulled sprue to give the prop hub some dimension.
An absolute delight to build.  High parts count, but a great first paper model as it is so well designed.
Now my Teutonic piano top has some Allied competition.  Thanks for looking...
Dan
« Last Edit: July 13, 2020, 03:21:29 AM by NinetythirdLiberator »
Re: SPAD XIII 1/33rd Papercard Model by Luis P. Igualada
« Reply #1 on: July 12, 2020, 03:40:22 PM »
Offline Radarman
« Reply #2 on: July 12, 2020, 03:49:30 PM »
Dan,
Fantastic work once again. I guess you will be stunning us soon with another bit of “paper magic”.
        Kevin
Offline smperry
« Reply #3 on: July 12, 2020, 03:55:20 PM »
Most excellent build Dan. The top wing is ruler straight and gives it that "Means Business" look of the Spads. Have to look twice to tell it is paper. You may have never met the designer, but there was definitely a meeting of the minds as you brought out the shapes that he thought up. Great piece of modeling.
Most inspiring to me this evening as I started on my first paper card model. A 1/24 scale Link Trainer. Being a first paper model, Trainer sounded appropriate. Twice as many pages of instructions as parts sounded good to. But mostly, I always wanted one. (a real one) Had an enjoyable evening making part of the box/pedestal it sits on, then came in and saw your completed masterpiece. What an encouraging boost.
sp
Offline Gene K
« Reply #4 on: July 12, 2020, 10:30:28 PM »
An absolute delight to follow, Dan. Thanks!
Is an Igualara Albatros in your "To-Do" list???? ::)
Gene K
« Reply #5 on: July 12, 2020, 10:38:09 PM »
Fantastic job on your Spad Dan ! :)
« Reply #6 on: July 12, 2020, 10:54:28 PM »
Remarkable results Dan! As always I enjoyed the build log! I can only hope that at least one of My SPADS looks half as good when completed! Thanks for the inspiration!!
« Reply #7 on: July 13, 2020, 02:21:08 AM »
 These paper models amaze me, I really must visit that section more. This is absolutely beautiful, wish I had followed the build thread.
« Reply #8 on: July 13, 2020, 02:46:15 AM »
A wonderful result once again Dan!  You've clearly got the paper figured out.  What a treat to follow your progress and completion of this SPAD! ;D  Very well done.
Best regards,
« Reply #9 on: July 13, 2020, 03:18:19 AM »
Thanks, Everyone...you should all give it a try as Matt77 has just given two Albi's downloads for FREE over in the Paper Models area!  You can't get better renderings and I've build a Nieuport and D-VII from the same designer (Fitter) and both were nice models.
I was really impressed with the SPAD design.  Just the way it came together was so impressive.  Again, it makes the modeler look better than they are.  And there is a lot more detail many of you would have added to take it over the top.
Just sayin'!  ;D
You are all much appreciated...Dan
« Reply #10 on: July 13, 2020, 03:23:08 AM »
Hey Gene... ;D
« Reply #11 on: July 13, 2020, 07:09:44 AM »
Wow!  Fantastic job!  I always find paper models amazing.
« Reply #12 on: July 15, 2020, 06:33:36 AM »
You are a past master with plastic Dan, now you are establishing a reputation with paper card models too. That is a simply super model - yes the kit may be of a very high quality but as with plastic it takes real skill to turn the kit into something special - and THAT is something very special. I would be very proud to have that model on my piano top.
Offline Gene K
« Reply #13 on: July 15, 2020, 06:51:24 AM »
Hey Gene... ;D
Oh yeah!!! 8)  Looking forward to The Show.
Gene K
Offline Dwaynewilly
« Reply #14 on: July 16, 2020, 09:26:52 PM »
Amazing what you accomplish with this medium. I'd be happy if my plastic efforts came out like this.
Dwayne
