Author Topic: Maquette 1:48 Morane Type 'G'  (Read 12691 times)
Offline ta152c
  • My threads are doing iron man numbers
« on: April 21, 2012, 09:19:38 AM »
Hello.
Does anyone have a set of plans for this Russian kit they could scan for me? Would be very helpful.
Regards :)
"I hope he burned all the way down" - Mannock on hearing of the death of Manfred Von Richthofen, 1918.
Re: Maquette 1:48 Morane Type 'G'
« Reply #1 on: April 21, 2012, 02:25:44 PM »
i have the kit i can make you a photocopy of the instructions and send them with the engines. i also dug up some links a while back let me check i'll be back.
Offline ta152c
« Reply #3 on: April 21, 2012, 07:02:01 PM »
Thanks Scott!
Enjoy your datafiles when you get them, hope you make use of them. *reminds self to photocopy the Triplane one . . .
Regards :)
Offline ta152c
« Reply #4 on: April 22, 2012, 08:00:25 AM »
Thanks Scott!
Have a look in the 'Under Construction' section, your links were a great help :) I got a PDF of the kit plans from a fellow called William Smith too, which saves you photocopying one. Saves the planet, so I'm ok with that.
Regards :)
