Author Topic: difference between fokker DVII V22 and MAG  (Read 3915 times)
Offline sgeorges4
« on: May 27, 2020, 02:42:58 AM »
Hello,
I got to wonder why did the V22 got a quad propeller but not the production aircraft,the radiator changed too
https://encrypted-tbn0.gstatic.com/images?q=tbn%3AANd9GcSlAhIskX7kKY9OEC86hGrjbC0OaQfVO8SLiGqtlGP2qJxkaRhV&usqp=CAU
thanks for your answer!
Offline Mossie
Re: difference between fokker DVII V22 and MAG
« Reply #1 on: May 27, 2020, 04:22:05 PM »
As the aircraft was for Austria, it was fitted with the 200hp Austro-Daimler engine and the Jaray propeller by Fokker at Schwerin. Also fitted were two Schwarzlose M.16 MGs. The aircraft did not perform as well as expected but was still shipped to Matyasfold in Austria, 24 Apr 1918, and given the designation '90.05'. V.22 remained a prototype as the Austrian's decided to go with MAG built Fokker D.VII's.
The MAG build D.VII's had 225hp Austro-Daimler engines and Schwarzlose MG's. None of these aircraft were delived in time for use, but were later found in Hungarain service.
Gerry "Mossie" Mos
Mossie3DCAD
"Prompt & Precise"
https://www.facebook.com/gerry.mos.9
Offline sgeorges4
« Reply #2 on: May 27, 2020, 04:25:28 PM »
That explain the different radiator then. I think that for a V22 base DVII MAG,the 1/72 scale eduard one can be use(the 1/48 scale comb doesn't have that much radiator option)
thanks!
