Author Topic: Sopwith Triplane 1/48, Upd 16.8.2020 Finale and a riddle again!  (Read 39055 times)
Sopwith Triplane 1/48, Upd 11.8.2020 Cowling and more
« Reply #135 on: August 12, 2020, 03:43:21 AM »
« Last Edit: May 31, 2022, 01:26:16 AM by Bughunter »
Re: Sopwith Triplane 1/48, Upd 11.8.2020 Cowling and more
« Reply #136 on: August 12, 2020, 04:16:11 AM »
Wow Frank!  It's hard to believe that's 1/48--it is far more detailed than my 1/32 WNW model of the same aircraft!  You have done a marvelous job with the details and finish on this Tripehound.  I particularly like the tires, tail skid and engine (actually, everything else as well!).  Very pleasing and enjoyable for we fans watching from home. ;D  Nicely done!
Best regards,
« Reply #137 on: August 12, 2020, 05:40:33 AM »
Frank,
The plate on the engine cowling is so small that I would have difficulty seeing that with my eye loupe (magnifier)! The amount of detail that you add to your models just takes my breath away every time I look at you updates.
Hope we like it? What a question to ask!!!
« Reply #138 on: August 12, 2020, 09:53:56 AM »
Ich liebe es Frank !
Offline smperry
« Reply #139 on: August 12, 2020, 10:17:12 AM »
Frank, your ability to hold and work on such tiny pieces amazes me, Be very nice to your fingers.
sp
« Reply #140 on: August 12, 2020, 10:08:08 PM »
Lots of small details here.
But that's Frank's forte.
Is that engine cowling plate upside down?
Just kidding  ;D
« Reply #141 on: August 13, 2020, 04:13:58 AM »
Thank you very much!
Bob I swear, that's 1:48 as all my bi- and triplanes :)
Stephen I must admit, that this was not foreseen as own part on the Parts PE set. It was attached to the cowling ring. But since I had the appropriate dark ring form the kit PE already on I cut the plate from the ring to mount it alone.
Vielen herzlichen Dank Terri!
For those parts I use a very small "Zeckenpinzette" - Tick tweezers? I don't know, if the one in the picture is also that small, but the layout is comparable.
Picture: amazon.de
;D ;D
Today I tried to mount the wings, so I had to do a lot of preparation with drilling holes for the rigging.
After the middle wing was glued in place, I noticed later with dry fitting the upper wing, that the middle wings are sitting to low :-[
Since the mm was missing below it increases the distance between middle and upper wing about the same amount, so it was immediately noticeable if one  look at it.
What did my math teacher used to say? "Symmetry is the aesthetics of primitives." So I broke out the middle wings again.
One step forward, two steps back.
« Reply #142 on: August 13, 2020, 06:37:45 AM »
Amazing details you have added Frank, I was thinking the same as Bob. It looks more detailed than my 1/32 WNW Tripe.
Like any other step back I know you will fix the middle wings and come back with another stunning update. I'm really enjoying seeing this little masterpiece come together. :)
« Reply #143 on: August 14, 2020, 01:11:58 AM »
Every update Amazes Me more Frank! Such precision in details and painting. Simply Gorgeous work on all!
« Reply #144 on: August 14, 2020, 01:51:23 AM »
Great detailing work, every single item is a gem. Congrats.
« Reply #145 on: August 14, 2020, 02:28:33 AM »
Thank you Richie, Rick and Giuseppe!
I'm sure, WNW has moulded details which I cannot simulate. The Eduard Triplane is a nice kit, and with some additions I try to enhance it further.
The bird has now 3 wings and the rigging is finished 8)
Need the process pictures and write some notes, so stay tuned for the next update ;)
Sopwith Triplane 1/48, Upd 13.8.2020 Rigging
« Reply #146 on: August 14, 2020, 03:36:20 AM »
« Last Edit: May 31, 2022, 01:26:25 AM by Bughunter »
Offline Radarman
« Reply #147 on: August 14, 2020, 03:39:13 AM »
Frank,
I always look forward to your updates. This build just keeps getting better!
        Kevin
Re: Sopwith Triplane 1/48, Upd 13.8.2020 Rigging
« Reply #148 on: August 14, 2020, 04:14:37 AM »
I could have used you to help make SPAD XIII fittings for MY builds!! Like I said, More amazing with each update!
« Reply #149 on: August 14, 2020, 05:40:31 AM »
« Last Edit: May 31, 2022, 01:26:33 AM by Bughunter »
