Author Topic: Wolseley Viper engined SE5a spinner needed  (Read 2947 times)
« on: April 27, 2020, 02:04:41 AM »
Did anybody build the 1/32 Wolseley Viper engined Roden SE5a and not build it as Schweinhund?
I'm after the little conical spinner that was fitted over the boss.
Mine just pinged across the room never to be seen again. White frustrating after spending 2 days carving a prop and making sure it fitted the boss perfectly. :(
Will happily buy it off you.
Please let me know if you can help.
Thanks
Offline RLWP
  • Bodger
Re: Wolseley Viper engined SE5a spinner needed
« Reply #1 on: April 27, 2020, 02:19:42 AM »
I thought I had replied to this - is there one in the Roden kit?
« Reply #2 on: April 27, 2020, 02:32:27 AM »
Hi Richard, yes I reposted here. Thanks for the reply, I don't think I made it clear as Roden also provide the engine as a separate kit. The little conical spinner is supplied with the kit which has the red SE5a on the front. It isn't included in the other 1/32 kit (I have both and just checked) but I might try to turn one out of 6mm plastic rod or just fit a resin boss and have done with it. Life's too short to obsess over little things like that, maybe...
Offline RLWP
  • Bodger
« Reply #3 on: April 27, 2020, 03:12:21 AM »
That is the kit I have
Which thread would you prefer to converse through?  ???
« Reply #4 on: April 27, 2020, 03:54:00 AM »
This would be fine Richard as we're here. :)
Offline RLWP
  • Bodger
« Reply #5 on: April 27, 2020, 05:59:40 AM »
Well, I'm afraid I have to let you down. I have checked my kit, that part is listed in the instructions, the kit has the 'Schweinhund' scheme, and that part is missing
What is odd is - I thought I had seen that part somewhere
« Reply #6 on: April 27, 2020, 06:39:11 AM »
No worries Richard, thanks for taking the time to look. I might make McCudden's kite or make Schweinhund without it.
Offline RLWP
  • Bodger
« Reply #7 on: April 27, 2020, 06:44:25 AM »
Just make one. A cone on a bit of rod, file the front off the prop and you are done
« Reply #8 on: April 27, 2020, 07:09:23 AM »
Yep, shouldn't be difficult. I wanted to start learning about scratch building. This would be a nice easy place to start.
