Author Topic: Rudolf Klimke’s Dr.1 in 1:32 scale  (Read 38662 times)
Offline phs Paddy
« on: April 17, 2012, 12:24:30 PM »
I am converting the Encore F.I “Voss” kit into that of Lieutenant Rudolf Klimke’s Fokker Dr.1 while with Jasta 27. The main documentation on the structure of the machine will be the Kagero “Fokker Dr.I The Aces' Aircraft” book. For markings and colours I’ll use the work sheet that came with the Cutting Edge decals “Fokker Dr.1 Part 2”. That’s Klimke’s machine in the lower left corner of the colour sheet.
First progress:
First I glued the photo-etch to thin Evergreen 0.13mm sheets and then glued the styrene sheets to the fuselage halves. I then primed the interior area and when dry sprayed my base acrylic colour for the bleached linen covering. I then masked the linen area from the plywood sides and applied artist oil Gold Ochre with a sponge attempting a grain look for the plywood.
My thought now is to spray the entire area with Tamiya X-24 Clear Yellow not only for the plywood effect but in hopes the bleached linen colour I mixed will show a touch of yellow improving the appearance. Not to happy at this point with the colour the linen has. After the clear yellow has cured I will apply a thin artist oil wash of Burnt Umber to the entire area to darken it up a bit. Fingers crossed as I try to reach an acceptable look.
Any thoughts or suggestions gratefully received.  :)
Paddy
Offline Rob Hart
Re: Rudolf Klimke’s Dr.1 in 1:32 scale
« Reply #1 on: April 17, 2012, 12:33:29 PM »
The wood grain looks good. Maybe a dusiting of tan pastels on the linen to relieve the starkness? Of course when you close the fuselage it will mostly be in shadow.
« Reply #2 on: April 17, 2012, 01:26:31 PM »
Nice wood grain Paddy, your idea of spraying the wood and the linen with Tamiya yellow sounds interesting, I'm keen to see the result.
« Reply #3 on: April 17, 2012, 09:31:04 PM »
Hi Paddy,
 Good to see progress on Klimpy's bird  ;)
Tamiya do a nice line in pastels. They can be applied dry with the applicator supplied or chipped into a small pot and thinned with tamiya thinner for a wash.
Perhaps a build up of thin washes will serve you well. Try it out on plastic card first  :)
Lord Von Buckle
« Reply #4 on: April 17, 2012, 10:07:21 PM »
Your woodgrain effect looks very realistic Paddy. After seeing the edging you added, I wish now that I had thought to do the same with my recent Dr.I, using some thin plastic strip. At the time it never occurred to me but I can see now just how much of a difference it would've made.
Offline phs Paddy
« Reply #5 on: April 17, 2012, 11:07:17 PM »
Hello Rob,
Thanks for that and the suggestion. I had not thought of using pastels and it sounds like a very good approach. I’ll be checking that out.
Thanks Des. I'll shoot the clear yellow on a test piece I made up using the same primer, base coat and artist oil to check the result before doing the fuselage. If that appears OK I'll pop a photo of fuselage so we can see the difference before making any other change.
BTW, love being aboard.
Hi Paddy,
Lord Von Buckle
All right LvB:) We seem to have a consensus building in that direction so just placed a “notify” at SB for the A set. Seems their out at the moment but they usually respond quickly. If I’m ready before they are I do have some of the Warpigs pigments in the inventory I’ve never tried and I’ll give them a shot.
Plain old water works well too  ;)
Thanks for that RB. BTW, I keep going back to your ‘Completed Thread’ and checking out the Bebe. One of my favorite kites and I love the job you did with her. The subtle shadows set things off. I’ll have to try and learn the technique.
Tally-ho Chris and thanks for that. Love your just completed Dr.I and if I can come just a wee bit close to your work I’ll be quite happy.
Thanks again gents for taking the time and posting your comments. I think I’ve fallen in with an outstanding group.  :)
Paddy
« Reply #6 on: April 18, 2012, 07:07:16 AM »
  Paddy,
Excellent progress and outstanding wood graining my friend.
Offline Pete Nottingham
« Reply #7 on: April 18, 2012, 07:39:15 AM »
Great start Paddy, excellent wood grain.
Pete.
Offline phs Paddy
« Reply #8 on: April 18, 2012, 11:49:07 AM »
  Paddy,
Thanks Gregory. Much appreciated
Paddy
Offline phs Paddy
« Reply #9 on: April 18, 2012, 11:51:32 AM »
Pete.
Thanks Pete. Its been fun trying to learn to do wood graining.
Paddy
« Reply #10 on: April 19, 2012, 12:44:11 AM »
Fun? Are we supposed to be having fun? Darn, I think I missed that memo.  ;D  Seriously though, you're past the 'trying' part Paddy. You've got the hang of it my friend!
Offline phs Paddy
« Reply #11 on: April 19, 2012, 12:59:58 AM »
 ;D ;D ;D Man, even when you hit some turbulence you come out right side up. You have the gift of a true craftsman and artist.
That’s kind of you to say and I thank you for that Chris.
Paddy  :)
Offline phs Paddy
« Reply #12 on: April 20, 2012, 12:02:03 PM »
Well Des, after going through a test spraying of the clear yellow over the linen its a bust and I'll now approach warming that cold linen bugger up in some other manner.........  I hope.  :-\ The clear yellow looks fine to my eye on the plywood but it will end there.
Back to the drawing board if I can get out of the inside of this dark Cumulus Nimbus without the wings coming off.   ;D ;D ;D
Paddy
« Reply #13 on: April 20, 2012, 02:26:29 PM »
Great start. Dont give up!!!!
« Reply #14 on: April 20, 2012, 05:29:39 PM »
Paddy!
You finished it yet?  ;D
Come come dear boy, pull your finger out!
Von armchairmodeller
