Author Topic: Revell 1/28 Scale Fokker D.VII  (Read 57423 times)
Re: Revell 1/28 Scale Fokker D.VII
« Reply #195 on: October 27, 2020, 08:46:38 AM »
Hey look ! she got leg's !  ;D
Offline Radarman
« Reply #196 on: October 27, 2020, 12:49:26 PM »
Fantastic, Kevin!  My wife and I just got back from a really nice 4 mile walk and man...the leaves are just amazing out there.
Your Fokker looks super awesome.  Really coming together now!
Can't wait for the finish,
Dan
Thanks Dan. It's been good to have a few nice days around here. I miss hiking around Dash Point.
Looks absolutely Awesome on it's wheels!
Thanks RAGIII. Your praise is indeed appreciated.
Thanks Terri. Yep, she's got legs and they're very sturdy.
Offline Radarman
« Reply #197 on: November 20, 2020, 01:33:50 PM »
Hello everyone,
I've been a little bit busy working outside the last few weeks so the Fokker has had to wait for a bit.
My current task has beed to make new struts to replace the flimsy bits provided with the kit.
After correcting the fuselage none of the struts work. I used my "Strutter" with 1.4 mm O.D. tube
and soft soldered them.
The interplane struts were pretty simple to make while the cabane tripod will require a bit of higher math.
Anyway, wish me luck. Happy Modeling!   Kevin
« Reply #198 on: November 20, 2020, 11:24:31 PM »
Okay, you lost me on the math bit , but other then that those struts are shaping up nicely Kevin  :)
« Reply #199 on: November 20, 2020, 11:39:10 PM »
Excellent use of Math, although Like Terri beyond Me  ::) The struts look great!
« Reply #200 on: November 21, 2020, 07:25:54 AM »
Kevin, I guess you know how much I like soldering. You have done the struts in the best possible way, this could not be done better !
I'm sure you will solve the tripod mathematics too, if you begin this task in such controlled way. 8)
« Reply #201 on: November 21, 2020, 10:40:25 AM »
Better use the big calculator.
« Reply #202 on: November 21, 2020, 10:45:36 AM »
Hay ... thats cheating !
Offline Radarman
« Reply #203 on: December 27, 2020, 04:34:39 AM »
Hello everyone,
Here's a short update on this build. I've spent the last month learning to use a "Vector Graphics"
program to make the artwork for my selected scheme. I then printed them out on white decal paper.
I'm modeling a Fokker D.VIIF from Jasta 46 flown by Fritz Haack.
I've also finished adding all the small bits to the top of the fuselage such as the guns, ammo feeds and blast protectors.
I'm to the point of attaching the upper wing and the final details.
        Happy Modeling!
        Kevin
« Reply #204 on: December 27, 2020, 06:33:44 AM »
That's looking sharp, Kevin.
Offline Fvdm
« Reply #205 on: December 27, 2020, 06:47:28 AM »
That's looking real nice. I really like the owl on the fuselage.
Offline Dave Brewer
« Reply #206 on: December 27, 2020, 09:10:16 AM »
Great work Kevin, you're doing wonders with this old kit.
Dave.
« Reply #207 on: December 27, 2020, 09:18:25 AM »
Sailing right a long wonderfully so far Kevin , looking forward to seeing the top wing in place . :)
« Reply #208 on: December 29, 2020, 04:19:04 AM »
Beautiful work !  What you are doing with this kit is awesome! The struts are looking terrific and I also look forward to seeing the DVII as a Bi Plane!
Offline Radarman
« Reply #209 on: December 29, 2020, 05:10:45 AM »
Thanks everyone for checking in.
Terri and RAGIII, as you wish!
Here the first few shots of the upper wing in place. The "N" struts have been glued in place and left to set.
As you can see, I took the option of adding the letter "G" to the top wing along with on under either lower wing. I though it might add to the overall look.
        Thanks again and Happy Modeling!
        Kevin
