Author Topic: WNW Albatros D.V Hans Auer, Jasta 32b  (Read 5516 times)
Offline Robin
Re: WNW Albatros D.V Hans Auer, Jasta 32b
« Reply #15 on: January 17, 2020, 12:11:29 AM »
Thanks again all,
Prez...I ordered the wrong Wolff (for a Bz.IV engine), but Proper Plane now also have the Wolff for an Albatros D.V, so that's solved :)
Fredrik...I might give the Proper Plane plywood decals a try. I know this will make you cringe. ;D
I'll decide when I get them...and after a test.
Leaning towards painting the black and white stripes...to be decided.
The tail must be green/mauve instead of black. The WNW manual isn't clear about that, but photo's show camouflage colours, so that's what I do.
Robin  :)
« Reply #16 on: January 17, 2020, 01:37:29 AM »
Although I know that you will build a beauty out of this kit, I regret that you dropped the plan to do the Halberstadt Cl. IV.
Anyway, I will follow your build with greta pleasure.
« Reply #17 on: January 17, 2020, 08:09:08 AM »
I have no problems with others using decals 🙂 and for woodgrain I think decals can be a good choice. Give them a go and decide later! As for the stripes it simply looks easier to me to paint them...
Offline Proper Plane
« Reply #18 on: January 21, 2020, 10:13:15 AM »
Nice!  :)
The wooden prop I ordered from Proper Plane isn't the one used on a D.V...my own fault.
I'll use that one on a DFW C.V (late), so no harm done. The right Wolff prop on order now. Together with plywood decals.
And uhm...a Barracuda engine intake manifold with asbestos insulation.
OOB he said.... :-X
Robin  :)
Hi Robin! You can make a change in your order if you want to. It's not late :))
Offline AlbertD
« Reply #19 on: January 23, 2020, 01:54:21 PM »
I'll pull up a stool and grab some popcorn for this one. The WNW D.V's are great kits. I wouldn't say they fall together but they fit well and are well engineered. I hope you try the Proper Plane woodgrain decals. I'm curious about how well they work. The HGW ones are a bit of a challange.
