Author Topic: H.M.I. 'Hydro monoplan 1' (Hansa-Brandenburg W.29 - WNW 1:32)  (Read 9612 times)
Re: H.M.I. 'Hydro monoplan 1' (Hansa-Brandenburg W.29 - WNW 1:32)
« Reply #30 on: January 27, 2020, 08:14:38 AM »
Great work on this seaplane, Kent!
As 1/48 builder I have the Flashback kit in stash, but your clean build and the references will help me later building mine, so following with interest.
Offline AndRoby67
« Reply #31 on: January 28, 2020, 03:27:56 AM »
Hi Kent,
until now your build is first class, I really love the carts, about them I have a question: they were "connected" by a bar or free? Only curiosity!
Painted markings added a touch of reality, really well done!
The (one or two?) candy striped W.29 in my informations was or were bought, the one that you are building, as you stated, was built in Denmark.
I don't think that the modeller that built the one with naval lozenge on wings and striped fuselage made a good decision. From photos that you posted,
it seems that, under the wings, there was a "worms camo" or something like that.
Roberto
« Reply #32 on: January 29, 2020, 04:13:52 PM »
This is a very beautiful and inspiring build to follow!
I have especially impressed by some of your efforts to break up the grey colour on fuselage and wings.
I will have to try and replicate some of this on my Pup. Keep up the good work!
Offline kkarlsen
« Reply #33 on: January 30, 2020, 01:08:09 AM »
Thank you Fredrik.
The wings on the Hansa-Brandenburg are just massive, something had to be done with the large surfaces.
I'm very pleased with the result too.
A couple of shots of the fnished 'H.M.I.'
Thanks for looking in: Kent
« Last Edit: January 30, 2020, 01:41:54 AM by kkarlsen »
Offline Gene K
« Reply #34 on: January 30, 2020, 03:06:53 AM »
Quote
Wings have been given a 'light' version of the salt weathering technique, to add some variation to the large grey surfaces.
I'm familiar with Salt Weathering, and I think it's usually overdone and unrealistic. However, your "light" version looks amazing, so would you please expound a little?
Gene K
« Reply #35 on: January 30, 2020, 03:38:45 AM »
Lovely work, Kent.
Super!
von B  ;)
Offline kkarlsen
« Reply #36 on: January 30, 2020, 03:48:10 AM »
Hi Gene, unfortunately I didn't take any photos of the 'light' technique.
However I will try to explain what I mean with 'light' using my last project were I used what I would call 'heavy' salt weathering.
I guess that's the one you are familiar with.
I used it to create a very weathered and well used surface on my Coast Guard Catalina...
After painting the basic surface color, which was white on the Catalina, I moistened the surface with water and applied ground salt (important to get different sizes of salt particles). Then several mixture of grey, brownish and dirty white was airbrushed to get the worn look. You can also remove some of the salt and apply it elsewhere to get varied layers.
And yes it is a mess working with it, but I haven't found any other method that comes close to the results you get this way.
I have even used it on NMF surfaces with similar great result.
Surface after salt weathering technique:
This kind of weathering would be 'over the top' for most projects...
Now what is it with the 'light' version? Well same technique, with about the same amount of salt applied to the surface.
The difference is to use very diluted paint and a color not too dissimilar to the base color.
This will add a 'milky' pattern/texture to the already darkened surface by the Flory dark dirt.
Hope this explains the 'light' a bit?
Cheers: Kent
Offline Gene K
« Reply #37 on: January 30, 2020, 07:45:05 AM »
Perfect, Kent. Thanks.
Gene K
Online Jorgo
« Reply #38 on: January 30, 2020, 09:40:15 PM »
Simply outstanding, Kent! And thank you for charing your ˋlight´ technique!
Jörg
« Reply #39 on: January 31, 2020, 02:37:26 AM »
Kent, after you moisten the surface (I assume you use a spray bottle of water) and apply the salt, do you let the moisture dry before spraying?  Some of the small salt particles must dissolve completely in the water and then gets dried out?  Does this interfere with the painting process?
Offline kkarlsen
« Reply #40 on: January 31, 2020, 04:26:23 AM »
Sorry, you are absolutely right Ken, I dry the salt/water mixture thoroughly with a hairdryer, leaving no wet spots anywhere.
If it would be wet it would interfere with the 'pattern' you are looking for!
Thanks: Kent
« Reply #41 on: January 31, 2020, 06:16:08 AM »
Thanks, Kent.  It's clear to me now.
« Reply #42 on: January 31, 2020, 06:43:19 AM »
Thanks for the explanation of the "Light" technique! I must say the end justifies the Means  ::)
« Reply #43 on: January 31, 2020, 07:08:22 AM »
Great results, Kent - that explanation and your photos are a great tutorial.
« Reply #44 on: February 10, 2020, 11:02:24 PM »
Perfect execution of this technique and an excellent description of the process.
