Author Topic: WNW's E.III (duellist version) Kornbeef  (Read 8704 times)
Offline kornbeef
« on: November 17, 2012, 10:03:48 PM »
I don't wish to distract form the other great builds here and I meant to post progress pics as I worked but never took any. Camera and time constraints.
So now she isnt as built as the pics indicate. Wings, rudder and cowl are all dry fitted.
My findings... There are a few points I thought WNW could have handled better but overall it's an impressive feat of egineering, tightly fitted engineering in places so be warned. WNW tolerances apply.
Downs are few: detail on the fuel control panel seems soft. I would have prefered the lower mount for the rudder bar assembly to be seperate from the front panel. The compass could have been moulded as a seperate item, I know it doesnt affect this build but the earlier E.III's need it removed from the wing risking damage to the detail nearby.
Basically thats the downers done.
Uppers: Some wonderfully thought out solutions to this planes eccentricities.
So a brief buld blog. All pretty much OOB so far apart from cutting the lower rudderbar mountings away from the floor and thinning them, adding a couple of pipes that are hardly visible. building up the guage on the fuelcontrol panel and replacing the hand fuel pressure pump pipe with copper wire. I added a map folder from a spare from some PE and have a few other small mods planned, Seatbelts and such have yet to be done.
The tail assembly is really femer, I've bent it twice while handling, I thing brass rod strengthenig is going to be a must here... For me at least.
Anyway, pics.
Yes theres a pushrod and rocker asembly adrift, I put it somewhere*coughs* safe... along with the small rod under the cockpit side that snapped off ..
As always comments, advice etc are always welcome
Keith
Re: WNW's E.III (duellist version) Kornbeef
« Reply #1 on: November 17, 2012, 10:28:10 PM »
Okay.  All of the upright shots look like a real 1:1 machine in an airpark somewhere.  Nuff said.  Great job!  I like!   ;D  Hope mine turns out as well.  ;)
« Reply #2 on: November 17, 2012, 11:24:15 PM »
Man, you nailed that natural metal effect! I don't think I've ever seen it done better. Secondly, but no less impressive, is your weathering technique. Very, very realistic looking. Superb workmanship.
« Reply #3 on: November 18, 2012, 12:34:03 AM »
   Kornbeef exposed as a fraud!!!!!
   He used a real Fokker E III to represent a scale model to the dismay of all his (former) fans...................but wait, it's the well known blackened oak stump in the photos for sure. Saved and reinstated to his highly respected status by his peers!
   Really Keith, what a beauty. Best "sworl" I've ever seen and the weathering/wear is absolutely perfect IMHO. And she's not even finished. What was the method for the pattern on the cowling?
  Very nice work indeed, you've really "Aced" this one"!
Offline kornbeef
« Reply #4 on: November 18, 2012, 01:08:17 AM »
Thanks guys.
LoL Lance.... nice.
The sworls are simple, copied from a suggestion here in a way. I primed the surface in mid/dark grey. painted the swirls in thinned Citadel Mithril silver (which is very bright) then after it dried coated it with Klear before drybrushing Citadel Runefang Steel over it (this is one of Citadels new layer paints which arent as opaque as their base paints.) The Runefang steel is a darker tone so dulls the mithril silver down while filling in the grey areas, you can vary how much by the amount of drybrushing done. Another nice side effect is it picks out any edges and details..and dodgy bits too.
Thanks for the poss feedback guys.
« Reply #5 on: November 18, 2012, 02:02:08 AM »
Excellent work and the sworl technique is a keeper!!!!
Offline Fokker boy
« Reply #6 on: November 18, 2012, 02:56:27 AM »
Once again, very nice work. It seems doubtful mine will turn out as well, but I'll try.
Kevin
« Reply #7 on: November 18, 2012, 04:50:13 AM »
I examined the photos closely, Lance, and I see no evidence of a stump of any sort.  Looks more like cracked and patched asphalt.  What I don't understand is why the curator would allow Keith to flip the plane over on it's back.
Brilliant job, Keith, even if it isn't yours.
WarrenD
« Reply #8 on: November 18, 2012, 05:06:13 AM »
I really do like your treatment of the metal, sworls, etc. Nice!
Offline LindsayT
« Reply #9 on: November 18, 2012, 06:36:34 AM »
It's the weathering and grime that do it for me. Love it!
LT
Offline Edo
« Reply #10 on: November 19, 2012, 04:02:10 PM »
Hey Keith!
This is a beauty!
As other had said the swirls are prefect!
And the grime.... Just beautiful!
How did you do that?
Thank you, ciao
Edo
Offline kornbeef
« Reply #11 on: November 20, 2012, 10:54:55 AM »
Hi Edo, thanks my old friend.
The grime is a mix of Lifecolor oil Tensochrome and Citadel Devlan Mud, Both are washes, brownish grey, perfect for this kind of thing. I use the Devlan Mud all over, it seems to tie things together nicely.
Keith
Offline Jamo
  • Wellington, NZ
    • My Smugmug album
« Reply #12 on: November 20, 2012, 06:58:51 PM »
Echo what the others have said about the cowling and metal panels - your finish is fantastic Keith. Definitely something to learn from.
Thanks for taking the time to share your build with us
Happy Modelling
James Fahey
« Reply #13 on: November 21, 2012, 12:43:54 AM »
Keith,
Love your build! great paint work and weathering!!
« Last Edit: November 25, 2012, 02:02:09 AM by RAGIII »
Offline Whiteknuckles
« Reply #14 on: November 23, 2012, 02:34:30 PM »
Excellent weathering Keith, she may not be completely finished yet but she looks a treat!!
Eternal Apprentice
