Author Topic: Sopwith Schneider, Special Hobby 1/48, Upd 14.2.2020 St Valentine's Day  (Read 34211 times)
Re: Sopwith Schneider, Special Hobby 1:48, Upd 25.1.2020 Cowling
« Reply #75 on: January 26, 2020, 11:08:34 AM »
Some challenges along the way with the cowl , but she does look really good in place . Engine bearing come out awesome , nicely done sir !
Offline kkarlsen
« Reply #76 on: January 26, 2020, 07:03:57 PM »
Inspiring work on the cowling..
Kent
« Reply #77 on: January 27, 2020, 12:33:56 AM »
Outstanding work on the cowl Frank!
« Reply #78 on: January 27, 2020, 06:55:46 AM »
Regarding your comment, I'm not clairvoyant - just been there, done that.
Your cowling is coming along very well.  Nice wood work on the prop and struts, too!
« Reply #79 on: January 30, 2020, 07:10:24 AM »
As usual Frank your wood and metal work is just stunning. As others have written, you are making things that many of us would not even think of making, let alone try!
Sopwith Schneider, Special Hobby 1:48, Upd 7.2.2020 Lettering
« Reply #80 on: February 08, 2020, 08:10:34 AM »
Thank you very much for your kind words!
Lettering
It's been a long time since I've been here ::)
In the meantime I continued working on the race plane.
The scratched rudder still got ribbons and is now ready for painting.
The fuselage and the tail unit I have primed white:
After painting in a linen shade I painted the lettering with the masks provided by a friend.
What can I say? I did not like it, because my template was not correct :(
The problem was also a cheerful mix of different times. After the race in Monaco, the biplane was converted to wheels and was freshly covered. The "Sopwith" lettering looked different after that.
So paint removed (the Alclad primer was strong enough) and first of all a seam from an etched part was added.
Then I familiarized myself into the vector drawing program Inkscape - great tool!
I prefer a generic program instead of some special programs e.g. for cutting plotters, the know-how can be used more widely, is not dependent on any updates by a mnafacturer and Inkscape runs on my Linux computer.
With the help of original pictures I redraw and cut the masks.
This is how it stays now, here the left side:
And right:
At the tail I added floats, water rudder and struts to the elevator.
For the water rudder I soldered a sheet metal plate into a slotted brass tube and soldered the reinforcements.
Elevator and rudder have received their linkages.
Except for a few fittings the tail is now finished.
And here the struts are on the fuselage and the fuselage on the floats for fitting test, that's how it will look like.
It doesn't look like much progress, but it was a lot of work.
Re: Sopwith Schneider, Special Hobby 1:48, Upd 7.2.2020 Lettering
« Reply #81 on: February 08, 2020, 08:22:13 AM »
The painting, markings, rudder and float rudder came out great Frank! The model looks terrific on the floats!
« Reply #82 on: February 08, 2020, 01:44:31 PM »
Schone Arbeit Frank  :)
« Reply #83 on: February 08, 2020, 06:51:40 PM »
Great work! Nice to see your new machine put to work.
Offline ondra
« Reply #84 on: February 08, 2020, 08:15:55 PM »
Brilliant work, Frank, well done indeed!
Ondra
« Reply #85 on: February 08, 2020, 08:38:26 PM »
Fantastic work, Frank, really brilliant! And it IS visible, that it was quite an amount of work.
« Reply #86 on: February 09, 2020, 12:29:52 AM »
I think your progress is quite significant!  One can now see the final product coming.
« Reply #87 on: February 09, 2020, 07:36:04 AM »
"It doesn't look like much progress, but it was a lot of work."
Frank I thought that we Brits were supposed to be the masters of understatement. Now you Germans are at it too....!
The model looks sooo realistic with all the additions and extra details. The tail float is especially appealing. Another winner in the making.
« Reply #88 on: February 10, 2020, 05:00:47 AM »
Very nice process. The results are amazing!!
« Reply #89 on: February 10, 2020, 06:46:42 AM »
Thank you very mach my friends! All your comments are highly appreciated!
Andreas, see you in FFB end of the month? This bird will be there, me too ;)
After a very productive weekend I have to prepare the next update ...
