Author Topic: Albatros Dr.I, Eduard 1/48, Upd 28.6.2020 Suspension  (Read 36720 times)
Re: Albatros Dr.I, Eduard 1/48, Upd 19.6.2020 Landing gear
« Reply #165 on: June 20, 2020, 05:31:35 AM »
You should be happy with how it looks Frank. It's beautiful work! I just noticed how cleanly painted all the tiny latches are on the fuselage too. Amazing detail painting, especially in 1/48.
I finally got my Gaspatch guns and rigging mounts today. They are really superb, thanks for the tip. They won't make it onto the Triplane but I'm looking forward to using them soon.
« Reply #166 on: June 20, 2020, 05:54:24 AM »
Thank you Richie!
That painting is easy, because those parts are little PE buggers, glued on after painting. See them on the right (showed this pic some pages before):
The Gaspatch parts are great - we live really in Golden Times regarding accessories :)
« Reply #167 on: June 20, 2020, 06:38:28 AM »
Looking sweet, Frank!  Your detail painting is excellent!
Albatros Dr.I, Eduard 1/48, Upd 21.6.2020 Control horns
« Reply #168 on: June 22, 2020, 06:13:14 AM »
Thanks Gaz!
Control horns
On this aircraft only 4 control horns are needed fro the tail plane, the rest is controled internally.
Eduard provided PE parts, but a bit long. I drilled a 0.284mm hole into 0.5mm brass pipes and soldered the pipes to the horns, as visible on the lowest. The I filed away the excess, so I got a stable connection for adding a "One End" turnbuckle, as shown on the right one.
On the PE set there are no spare horns, so I searched for one finished part on the floor the same time, as needed to build all. Damn!
This soldering reminds me that I really like it, so I started something different. More soon!
Re: Albatros Dr.I, Eduard 1/48, Upd 21.6.2020 Control horns
« Reply #169 on: June 22, 2020, 06:26:41 AM »
Wow. That's amazingly tiny!
« Reply #170 on: June 22, 2020, 07:18:34 AM »
You continue to amaze me Frank, you must have incredible eyesight to make such tiny parts and be able to find them on the floor!  ;D
« Reply #171 on: June 22, 2020, 08:44:06 AM »
Thumbs up !
« Reply #172 on: June 23, 2020, 12:22:41 AM »
I Truly don't know how you do this stuff in any scale! You are a Magician  :o
« Reply #173 on: June 29, 2020, 02:12:34 AM »
Thank you my friends!
Suspension
The landing gear was not yet finished, axle and suspension are missing. So let's continue on that one.
The base was a picture set of James Fahey of an Albatros D.V, thank you very much!
At first I need some washers for soldering. I don't want to ruin my punch and die set so I do it a different way.
I drilled 1mm holes in a brass PE stripe, cut 5 pieces and soldered on a 1mm brass as block. I trimmed it in my lathe to a round block.
After desoldering I have 4 identical brass washers, to be soldered onto the nickel silver axle. Luckily I had a spare in the block, because I lost one.
After clean up the axle is prepared:
I painted the metal parts with grey green (Drooling Bulldog paint).
After painting the lower sharp bend with leather color I connected the parts by using bright grey stretched sprue as rubber simulation. In the middle the brown leather paint is visible, I forgot a picture.
And that is the view from top. I hope, the sprue can hold the heavy model! I secured it with CA.
And the final view with wheels.
The tires are not painted. Should I left them as they are or paint them too?
I like the look of the fully scratched metal landing gear, even if the suspension is not working ;)
Offline Radarman
Re: Albatros Dr.I, Eduard 1/48, Upd 28.6.2020 Suspension
« Reply #174 on: June 29, 2020, 02:39:28 AM »
Frank,
Thanks for another informative lesson in technique and another mind blowing demonstration of modeling skill.
        Kevin
« Reply #175 on: June 29, 2020, 03:08:37 AM »
I agree with Kevin: that is incredible modelling Frank - so realistic. With reference to the tyre colour I would leave them as they are.
« Reply #176 on: June 29, 2020, 04:01:46 AM »
Incredible work on the gear and suspension Frank!
Offline Early Bird Fan
« Reply #177 on: June 29, 2020, 04:03:55 AM »
Loving your work on the suspension, imho i’d be inclined to leave the tyres as i think they look great as they are
« Reply #178 on: June 29, 2020, 09:05:19 AM »
Fantastic work Frank !
« Reply #179 on: June 29, 2020, 04:30:39 PM »
Love that LG!
