Author Topic: Sopwith Pup B1807  (Read 7445 times)
Re: Sopwith Pup B1807
« Reply #15 on: December 09, 2019, 03:42:53 AM »
Beautiful build Richard, at least IMHO. I'll build one of these one day, as of now, the Pup is the only WNW kit I own. Meanwhile, I'll mess up some 1/72nd kits first.  ;)
WD
Offline RLWP
  • Bodger
« Reply #16 on: December 09, 2019, 05:07:48 AM »
WD
It's a very good, well designed kit. And being a single bay biplane not too much rigging. The way the struts are handled is particularly good. I have built 1:72 kits that are far worse
My problems were mostly due to things I did in addition to the kit parts
And a Sopwith Pup must be one of the most beautiful WW1 aeroplanes
Offline RLWP
  • Bodger
« Reply #17 on: December 09, 2019, 06:29:10 AM »
For example. The upper wing fixed in place on the cabane struts:
All nice and well located, leading edges parallel and enough flex in the wings to fit the outer struts later. This way, I have good access to the cabane to do the rigging without the struts getting in the way
« Reply #18 on: December 10, 2019, 12:17:49 AM »
Looks Fantastic Richard.
« Reply #19 on: December 10, 2019, 12:10:59 PM »
What are you using for the rigging ?
« Reply #20 on: December 10, 2019, 04:50:14 PM »
It looks good! Nice, clean and precise!
Offline RLWP
  • Bodger
« Reply #21 on: December 10, 2019, 07:08:43 PM »
Invisible thread, copper wire eyelets and brass tubes. Same as the DH.2
« Reply #22 on: December 11, 2019, 04:41:22 AM »
Good to see another Pup nearing completion.  Nice work, Richard.
Offline Ringleheim
« Reply #23 on: December 11, 2019, 03:04:38 PM »
She looks great!  I have always liked the lines of the Pup and would like to build this kit myself some day.
Keep going!
Offline RLWP
  • Bodger
« Reply #24 on: January 06, 2020, 08:44:33 PM »
This project seems to have gained a bit of momentum:
« Reply #25 on: January 06, 2020, 10:29:15 PM »
Nice, accurate rigging around the tail and landing gear, Richard.
I see this version has a propellor driven air pump on the landing gear strut.
Offline RLWP
  • Bodger
« Reply #26 on: January 06, 2020, 10:34:09 PM »
Thanks Ken
You may be aware, this project has been going on for years. Yesterday, I knocked off several things that had been causing me to shelve this, like the rudder lines, the flying wires under the lower wing and that Rotherham pump
I have often found this - things that appear impossible when thinking about them turn out to be simple when you have tools in your hand
« Reply #27 on: January 07, 2020, 07:14:30 AM »
Thanks Ken
 Excellent results on the tail rigging! I agree completely about things you let hold you back on a model. On My Off Topic build it was the Nacelle conversion, turned out to be pretty straightforward... also a four year delay  ::)
« Reply #28 on: January 07, 2020, 11:51:53 AM »
Nice work on the tail Richard , I'm at that stage with the rumpler ....I feel the annoyance . I'm looking forward on future progress , so far this is turning out to be a cracker !
Offline RLWP
  • Bodger
« Reply #29 on: January 13, 2020, 03:47:03 AM »
I think, at last, this one is done!
So there we are, a Gnome engined WNW Sopwith Pup from before WNW made one. Vector resin engine, vac formed cowl made by me
