Author Topic: Macchi M-5  (Read 64755 times)
Re: Macchi M-5
« Reply #60 on: January 09, 2020, 05:56:11 AM »
I thought I get back into the Macchi M.5 by hitting the beaching trolley and trestles first.
The four tie rings on the corners of the beaching trolley are metal rings.
The photo-etch parts supplied in the kit are flat and two-D.
Therefore I cut away the 'rings' from the photo-etch parts and replaced them with rings of 0.5 mm diameter lead wire.
I also modified the photo-etch tie ring holders to suit the replacement rings.
Also in the photograph (thanks 'huberlu') you can see protective padding, which I'll be adding to the trolley and trestles.
Re: Macchi M-5
« Reply #61 on: January 09, 2020, 12:02:35 PM »
Awesome Hardware!
Re: Macchi M-5
« Reply #62 on: January 10, 2020, 10:39:15 PM »
The beaching trolley and support trestles are done.
The metal wheel rims were annealed to make them easier to bend and to give a better 'used' look.
The wood beaching trolley and trestles were stained with 'AK Interactive' wood wash, then sealed with 'Alclad' Flat (ALC314).
The top padding was represented with 'Tamiya' Rubber Black (XF85) and algae staining by water based ‘Derwent’ Inktense 24 pencils.
Wear on the padding was from sponging 'Tamiya' weather set E (green) and dirt on the axle from 'Flory Models' dark dirt wash,
Offline RLWP
  • Bodger
Re: Macchi M-5
« Reply #63 on: January 10, 2020, 10:48:39 PM »
It looks like you have taken up medieval wargaming!
 ;D
Re: Macchi M-5
« Reply #64 on: January 10, 2020, 11:12:27 PM »
Well at my age I sometimes feel pretty 'medieval'  ;D
Re: Macchi M-5
« Reply #65 on: January 10, 2020, 11:40:52 PM »
Wow Mike, I can almost taste the sea salt from here.  Looks fantastic.
Re: Macchi M-5
« Reply #66 on: January 11, 2020, 01:45:48 AM »
...and the Hardware looks even better on the Beautiful Beaching apparatus!
Offline AndRoby67
Re: Macchi M-5
« Reply #67 on: January 11, 2020, 05:19:59 AM »
Wow!
I think that your trolley and trestles are better than the original ones!
Wonderful!
Roberto
Re: Macchi M-5
« Reply #68 on: January 11, 2020, 08:08:31 AM »
True to form this kit has already shown problems.
The instructions indicate where the forward bulkhead and pilot's seat support should be located.
The bulkhead locates on the hull bottom (effectively the cockpit floor).
If the instructions are followed, it will result in the hull bottom not fitting into the fuselage as the bulkhead would be too far forwards.
The pilot's seat support location is such that, when fitted, the pilot's seat is too far rearwards in the cockpit, so needs to be moved forwards on the seat support.
This means the control column is then too close to the seat.
The forward bulkhead is shown in the correct location.
The pilot's foot boards assembly may need to be modified to move the control column forward and away from the pilot's seat
« Last Edit: January 12, 2020, 03:50:54 AM by Mike 'Sandbagger' Norris »
Offline Dave Brewer
Re: Macchi M-5
« Reply #69 on: January 11, 2020, 02:32:14 PM »
Lovely work on the beaching gear Mike.I spent a couple of hours yesterday pressure cleaning a year's accumulated gunk off my boat yesterday and you achieved the same look beautifully.It's fortunate you spotted the issue with the plans,things like this leave me shaking my head at times,pure carelessness on the manufacturer's part.
Dave.
Re: Macchi M-5
« Reply #70 on: January 11, 2020, 09:56:33 PM »
Dave.
Thanks Dave.
It helps spotting problems having been an engineering toolmaker for 6 years, then 27 years as a technician in the RAF and lastly 20 years as a miltary aircraft technical author.
Sort of second nature spotting these sorts of problems,
Offline huberlu
Re: Macchi M-5
« Reply #71 on: January 11, 2020, 11:29:50 PM »
Some Pictures:
Offline huberlu
Re: Macchi M-5
« Reply #73 on: January 12, 2020, 01:29:33 AM »
Thanks all.
Huberlu:
Thanks for these drawing etc - some of which I have.
The photo is interesting - It looks like the control column with torsion bar and aileron bell crank lever for the aileron control cables (rear cockpit to underside of upper wing?
Offline huberlu
Re: Macchi M-5
« Reply #74 on: January 12, 2020, 02:27:20 AM »
I believe, but I am not sure if I translate what you write well.
The triangular body placed on the Macchi under repair is the base of the seat.
