Author Topic: Removing enamal paint  (Read 3304 times)
Offline sobrien
« on: November 16, 2012, 03:40:24 AM »
First let me say that I am a brush painter. I started on my WNW SE5a and am not happy with the paint I was using for CDL. It did not cover thinly enough and is not setting well. Luckily I was only painting the inside of the fuselage. What is the best way to remove the paint without damaging the plastic?
Thanks for any help,
Sean
Re: Removing enamal paint
« Reply #1 on: November 16, 2012, 04:18:10 AM »
Hmmm....enamel does etch into the plastic a bit so Im thinking letting it cure then sanding lightly. Oven cleaner I think was another option but Im going to let someone else confirm that.
« Reply #2 on: November 16, 2012, 05:35:37 AM »
Have a look at the link below Sean, it may give you some good ideas, read the entire link as there are quite a few different techniques mentioned.
http://www.therpf.com/f11/how-remove-enamel-paints-plastic-kits-149695/
« Last Edit: November 16, 2012, 05:37:13 AM by Des »
Offline sobrien
« Reply #3 on: November 16, 2012, 06:16:20 AM »
Thank you Des and Steve for your help.
Sean
Offline ETG
« Reply #4 on: December 20, 2012, 05:23:53 AM »
What's easier than oven cleaner? Never fails.
Just remember it's dangerous stuff. Wear long rubber gloves and a mask. You do NOT want to inhale this stuff..!!
Take a strong, leak proof plastic bag, insert a good squirt of oven cleaner, put the model in the bag, and cover the model
in OC. Leave overnight.
(Edit: while the model soaks, keep the bag closed with a rubber band or clothes pin)
Put your gloves back on and take the model out. Rince, while rubbing with a large brush. You'll see the paint just flow
away while the plastic is totally unharmed.
(Here we see the disadvantage of acryllics....When dry, it is a sort of plastic, too. So, what do you use to remove it from
a plastic model? Pure alcohol works best, but veeeery slowly. Endless rubbing with a firm brush, dissolving the paint.)
____________
Erik.
« Last Edit: December 20, 2012, 10:57:11 AM by ETG »
« Reply #5 on: December 20, 2012, 07:09:59 AM »
Sean,
I've used regular window cleaner (with amonia) on both acrylics and enamels with good success. I use "Windex" and it's very quick on acrylics, enamels take two or three treatments. Just soak the parts in a bowl or dish, give it a few hours, and scrub with an old toothbrush to remove the paint. Any stubborn paint remaining, repeat the process. I've never had any damage issues, hope this helps.
« Reply #6 on: December 20, 2012, 12:30:05 PM »
  Sean,
To the suggestions and tips from above I'd add the spray on type whitewall cleaner. I can't remember the brand I here but it's available at any Auto Zone or Walmart.
« Reply #7 on: December 27, 2012, 10:46:05 PM »
  Sean,
I suppose you mean Westley's Bleche Wite -- never tried it for this purpose, only used it for what it was intended, but I believe it; it is rather nasty stuff. They warn you to keep it off the car's paint, so that should tell you something :)
WarrenD
« Reply #8 on: December 28, 2012, 09:48:58 AM »
I have seen Bleche White recommended in the past for removing mold release from resin parts.
« Reply #9 on: January 08, 2013, 03:39:32 PM »
if you can get it try "scalecote" its a paint remover designed for plastic models. it works great. i also use it as brush cleaner. but you can also try the main ingredient in scalecote which is very cheap. goto the drugstore and get some 91% isopropyl alcohol. it works and its $1.99 for a pint.the cleaner "simple green" works but not as well. i use a stiff paintbrush with all of the above to get the paint off quicker and out of the creavaces
« Last Edit: January 08, 2013, 03:41:09 PM by ALBATROS1234 »
