Author Topic: Karl Bolle's Fokker DR.I  (Read 4342 times)
Offline skeeterbuck
« on: October 07, 2019, 11:58:39 PM »
Eduard kit with Gaspatch MG's & Aviattic streaked camo decals. Fuselage bands and lower wing crosses were masked off and painted on.
Re: Karl Bolle's Fokker DR.I
« Reply #1 on: October 08, 2019, 12:22:12 AM »
Really Terrific DR1! The streaking decals look awesome as does the weathering! Awesome build!
« Reply #2 on: October 08, 2019, 12:25:49 AM »
This is the beast streaked Dr.I I have ever seen. Those decals are the most realistic way to depict streaking, IMHO.
Great job all around!
« Reply #3 on: October 08, 2019, 01:52:19 AM »
Beautiful job. Great work with the decals and nice subtle weathering, a model to be proud of!
« Reply #4 on: October 08, 2019, 01:54:17 AM »
Congratulations on a beautiful build.
Offline Robin
« Reply #5 on: October 08, 2019, 03:41:15 AM »
Beautiful.
Very nice weathering and the Aviattic streaking decals look superb.
No issues with masking on decals?
Robin  :)
« Reply #6 on: October 08, 2019, 04:25:01 AM »
That is a terrific model. The mud and wear is super - not overdone at all but very convincing. Stunner!
Offline skeeterbuck
« Reply #7 on: October 08, 2019, 06:48:54 AM »
Beautiful.
Robin  :)
Robin, I'm not sure exactly where you're referring to. If it's the crosses on the upper wing, I panted the background color first and then carefully trimmed the streaked decals up to the painted edge. I also did it the same on the fuselage sides. Decal from the cowl to the bands around fuselage and paint the rest of the way back.
Offline Robin
« Reply #8 on: October 08, 2019, 07:16:15 AM »
Ah! I was wondering about the use of masking tape on the streaking decals to paint "things" on them....like the fuselage band.
You didn't.  :)
Offline aircare84
« Reply #9 on: October 08, 2019, 09:33:39 AM »
Very well done!
Did you paint the lower color, or is it decal as well?
And, how did you do the prop, it is very convincing.
« Reply #10 on: October 08, 2019, 12:06:39 PM »
Verrrry Verrrry nice ! :) :) :)
Offline skeeterbuck
« Reply #11 on: October 08, 2019, 12:20:46 PM »
Very well done!
The underside blue is paint. I used Mr. Color C20 Lt. Blue for the base coat, then masked the ribs and lightly sprayed Mr. Color C117 & C118 which are both slightly different shades of Lt. Blue. The removed the masking and sprayed a final coat lightly to blend the different shades together. The prop was done by painting Mr Color C44 Tan then cutting thin strips of Tamiya masking tape. After applying them, I sprayed Mr. Color C43 Wood Brown overall. The finished with several light coats on Tamiya Clear Yellow. I like using Mr. Color paint because it's lacquer based and when applied lightly as I do with an airbrush it dries rather quickly and adheres well. I rarely, if ever have trouble with lifting paint when masking. The down side is that it has a strong smell so you should have a spray booth to extract the fumes outside. I can spray and don't even smell the paint. Hope this helps.  :)
Offline kkarlsen
« Reply #12 on: October 08, 2019, 03:22:21 PM »
What a beautiful build!
Kent  :)
« Reply #13 on: October 08, 2019, 08:37:23 PM »
That‘s truely wonderful and among the best triplanes I‘ve ever seen in any scale.
Offline Jorgo
« Reply #14 on: October 09, 2019, 03:59:20 AM »
Modeling at its best!
Best regards,
Jörg
