Author Topic: Aviatik 'Berg' D.I  (Read 38208 times)
Re: Aviatik 'Berg' D.I
« Reply #15 on: October 07, 2019, 04:44:48 AM »
Excellent work on the engine Mike!
« Reply #16 on: October 07, 2019, 06:22:00 AM »
Got my chair and Pepsi ...I'm all set  :)
« Reply #17 on: October 07, 2019, 08:18:41 AM »
My you have got off to a flying start! The engine looks most impressive and certainly looks as though it has had a few hours in the air. The problems you listed at the start are mere trivia for a modeller with your skills.
« Reply #18 on: October 07, 2019, 03:25:02 PM »
Wonderful start, Mike,
I am very happy to see this kit made by you. Allways straved around this one but first wanted to see it build by someone with good skills.
I think this will be an absolute stunner....as allways by you ;-)
Bye,
« Reply #19 on: October 07, 2019, 04:39:02 PM »
Great start, and a great, captivating subject. Will follow with interest.
« Reply #20 on: October 09, 2019, 07:25:56 AM »
The engine is now completed.
I've added the ignition leads and spark plugs, timing mechanism, oil filler caps, water pump and coolant pipe, vale levers and springs and carburettor lever.
I've also made the exhaust pipes from 1.8 mm diameter brass tube mounted onto 1.4 mm tube - the kit items had 'solid' bores.
Test fitted into its mounting frames.
« Last Edit: October 15, 2019, 07:24:32 AM by Mike 'Sandbagger' Norris »
« Reply #21 on: October 09, 2019, 07:38:07 AM »
What a great and promising start!
« Reply #22 on: October 09, 2019, 08:10:13 AM »
Mike!  It's not really sportsmanlike to post photos of a real engine and claim that it's your 1/32 scale model.  Honestly, I expected so much more from you.
(magnificent work as always, mate)
« Last Edit: October 09, 2019, 12:23:25 PM by coyotemagic »
Offline Robin
« Reply #23 on: October 09, 2019, 08:40:11 AM »
Whoppingly good this.
Robin  :)
« Reply #24 on: October 09, 2019, 10:23:08 AM »
Mike!  It's not really sportsmanlike to post photos of a real engine and claim that it's you 1/32 scale model.  Honestly, I expected so much more from you.
Bud has point , thats cheating !
« Reply #25 on: October 09, 2019, 07:54:05 PM »
Thanks.
Bud-Terri:
Not the first time I've been accused of that  ;D
« Reply #26 on: October 09, 2019, 08:07:45 PM »
If that actually is the case, then I'm more impressed by the enormous white paper on which the real engine rests...
« Reply #27 on: October 09, 2019, 08:34:29 PM »
 ;D ;D
« Reply #28 on: October 09, 2019, 10:11:05 PM »
Simply Gorgeous engine Mike! The different tones are beautifully rendered!
« Reply #29 on: October 09, 2019, 10:34:44 PM »
Great looking engine, Mike.
