Author Topic: Albatros D.II, Jasta 16b 1/48 Eduard (finished)  (Read 18440 times)
Offline aaronc
Re: Albatros D.II, Jasta 16b 1/48 Eduard (finished)
« Reply #90 on: November 20, 2019, 07:48:17 AM »
Great build to read through.... will be very helpful down the road to a rookie.
Offline Robin
« Reply #91 on: November 20, 2019, 08:13:11 AM »
Thanks all. :)
Robin
Offline Softscience
« Reply #92 on: November 20, 2019, 02:53:10 PM »
Robin,
I just went through this whole thread step by step, and I need to thank you for sharing so many great techniques. I'm intrigued by your pinning of the struts. How small of a drill do you use for this, and are you using brass wire for your pins or something more maleable?
I want to try this for the janky looking struts that are on Eduard's Fokker D.viii
Offline Robin
« Reply #93 on: November 20, 2019, 06:30:47 PM »
The struts I pinned were beefy enough for a 0,4 mm drill and matching brass rod.
The struts on my Fokker D.VII are really too thin for drilling and pinning  I think. Yours are probably that thin also.
I've seen people make new struts from flattened brass tubes (Albion Alloys) with brass or nickel silver rods inserted.
Not done that myself yet, but it seems not overly difficult.
Robin :)
« Reply #94 on: November 20, 2019, 11:02:39 PM »
Beautiful build, Robin.
Your rigging looks like it was strung by a past master - you learn QUICK!
Question. I'm liking Camo paint job. Which brand of thinner did you use for the paint? And did you use retarder?
Whenever I spray Valejo paint I get tip dry and clogging. Clearly, I'm doing something drastically wrong  ::)
Cheers!
Von B
« Reply #95 on: November 21, 2019, 12:42:23 AM »
On my Fokker D.VII I used 0.3mm brass pins, works fine.
And,
yesterday a nice little package arrived, containing this Eduard Profipack D.II kit ;)
So with the Gavia D.I I can build a bigger range of Albatros types (if I live long enough to build my stash ::) )
Offline Robin
« Reply #96 on: November 21, 2019, 01:07:06 AM »
Cheers!
Von B
I only use the Vallejo Airbrush Thinner.
Very thin mixture, minimal pressure and minimal amount of paint (trigger). Only recently "seen the light" myself.
Took me a while.  ;D
Frank, you're right I need new good quality 0,3 mm drill bits...the ones I have lost their edge.
The Gavia is the same kit as Eduard :-\
I have the Gavia W.4 and D.I....they're also Eduard clones.
Robin :)
« Reply #97 on: November 21, 2019, 04:20:22 AM »
Not completely - there is an additional sprue with new struts. The inner inverted V-struts are interesting.
And new decals of course.
Yeah, I have not understand the business relationship. Same boxes, same moulds but colorful manuals.
May be intended as luxury brand?
At least the W.4 mould seems to be lost since the Gavia release. The Gavia Pfalz E.I injection moulds appeared again at Special Hobby in 2016 :D
Offline Robin
« Reply #98 on: November 21, 2019, 04:27:01 AM »
Yep....btw the different strut is for a D.I  :)
« Reply #99 on: November 21, 2019, 04:45:58 AM »
Another thing to add to the shopping list.
Thank you!
von B  ;)
« Reply #100 on: November 21, 2019, 07:21:25 AM »
For a first attempt at rigging you have done exceptionally well. I can see that in future your model builds are going to be a must to follow.
« Reply #101 on: November 22, 2019, 05:22:39 PM »
Superb work, Robin. Very clean build!
Bye,
Offline Dave Brewer
« Reply #102 on: November 22, 2019, 05:47:54 PM »
Lovely Robin,tidy,clean attractive modelling.Time for a Wingnut kit!
Dave.
