Author Topic: Rodens SSW D.III 1/32  (Read 49480 times)
Re: Rodens SSW D.III 1/32
« Reply #240 on: December 05, 2019, 10:46:14 PM »
Maybe you've tried this, but can you make the Uschi line stiff enough for passing through tubing by applying a coat of thin CA glue and letting it cure while holding a small amount of tension on it?  This will make it stiffer and straight without making the diameter larger.  Do this on the end of the line only.
« Reply #241 on: December 06, 2019, 01:38:40 PM »
Use away Fredrik  :)
Ken , yes I did find that when messing around with ways on working with the line , but my results only ended in the end curling up  , maybe more tension ...
« Reply #242 on: December 06, 2019, 05:04:46 PM »
Hi Terri,
 Stretch and then glue an inch from the end. Allow to dry and then snip off the waste. Keep the line under tension throughout.
Lovely work BTW  :-*
von B
« Reply #243 on: December 06, 2019, 06:23:28 PM »
Lovely updates, she's going to be a very nice SSW.
Offline Robin
« Reply #244 on: December 06, 2019, 07:00:15 PM »
Good job dealing with this "wet noodle" line Terri. :)
« Reply #245 on: December 07, 2019, 02:17:36 PM »
Putting on Lindemanns new album F&M I got down to business and got the top wing mounted . Had to make a few adjustments to the holes for the pins in the top wing and trim back a few pins , but she all fit perfect and the wing is straight ! I will let it sit overnight giving time for all the joins to harden up even more .
Thanks guys for the kind comments ! And Bob for the tip  :)
« Reply #246 on: December 08, 2019, 12:59:41 AM »
Excellent work T! It is good to see that you managed to get the wing on without the warp one often sees with this kit!
« Reply #247 on: December 08, 2019, 11:00:12 AM »
Thanks Rick  :) I'm very pleased how it all lined up . glad I spent the time test fitting before committing to paint and decals .
I'm almost done with the main rigging with only two more lines to go .
« Reply #248 on: December 08, 2019, 12:38:18 PM »
Okay this is the most frustrating product I used for rigging . Took some damage causing more paint repairs . I had to re do many ...many ...many turnbuckles and line . Walking away multiple times . Landing gear is fixed and rigged as well . I did lose one line . Right rear side while trying to fit the bell cranks which ended up in the trash . Windscreen ended up in the great blue yonder . This almost ended up in the trash ...but away way here is my crappy efforts on a project which was going so well .
« Reply #249 on: December 08, 2019, 12:38:57 PM »
Offline Robin
« Reply #250 on: December 08, 2019, 08:21:58 PM »
Despite all the frustration and mishaps with the finish in sight...it still looks good T.  :)
Robin
« Reply #251 on: December 08, 2019, 10:38:10 PM »
Thanks for the up-lifting comments Robin  8) . I should have this finished today . Only got the flight controls left and a few touch ups and this one will be done .
« Reply #252 on: December 08, 2019, 11:21:48 PM »
I agree with Robin, it does look like a good result! Very beautiful paint scheme and the plane it self is a beauty! /Fredrik
Offline Gene K
« Reply #253 on: December 09, 2019, 12:08:09 AM »
Great outcome, but which specific "product" is the most frustrating?:
Gene K
« Reply #254 on: December 09, 2019, 12:32:11 AM »
Terrific recovery T! Looks outstanding!
