Author Topic: COMPLETED: Albatros DVa Guillow's Free Flight 1/20th Scale  (Read 8813 times)
Offline NinetythirdLiberator
« on: August 01, 2019, 12:05:52 PM »
All,
Well...she's as done as she can be.  I went kind of heavy on the extra detail since this is a detail oriented site!  I made the engine from drinking straws, some aluminum tubing, balsa and bits of plastic.  The exhaust is balsa.  Because the geometry of the model is a bit off in the nose as represented on the kit, I needed to fudge a few things like...you'll see that the 6th cylinder doesn't have an exhaust portion attached.  I tried, but it looked dumb and at an odd angle so I left it off and won't tell anyone (other than you folks).  ::)
The radiator tubing is some melted and bent sprue with the straight parts being uncooked pasta.  It appeared to be the perfect thickness so there you go...I added tape at the junctions which approximates hose clamps areas etc.  I made sure this engine was high compression with a red line on the first cylinder.  This guy will need all the help he can get.
Machine guns are made from plastic straws perforated with a small screw driver with bits of plastic for the flash suppressors and balsa breaches.  She glides nicely as is but we'll see what happens under power.  I will post a link to a (hopefully) successful flying video soon.  Keep your fingers crossed.
Thanks to Dave for running this and, of course, all of the contributors as there have been some SWEET models here.  Des would have enjoyed this immensely!  A fitting tribute I must say... :)
Dan
« Last Edit: August 01, 2019, 03:42:26 PM by NinetythirdLiberator »
Re: COMPLETED: Albatros DVa Guillow's Free Flight 1/20th Scale
« Reply #1 on: August 01, 2019, 12:07:38 PM »
More shots...
« Reply #2 on: August 01, 2019, 12:12:17 PM »
Wow , she is awesome ! Your engine turned out super and does look the part . Well done ! Now I really looking forward to video of her flying  :)
« Reply #3 on: August 01, 2019, 12:12:54 PM »
Even more...
« Reply #4 on: August 01, 2019, 12:13:50 PM »
Still more...
« Reply #5 on: August 01, 2019, 12:14:20 PM »
And finally...
« Reply #6 on: August 01, 2019, 01:51:54 PM »
Okay , now your just teasing  ::) Love the under shot of wings . My fav pic !!!!!
« Reply #7 on: August 01, 2019, 02:44:35 PM »
Thanks, Terri.  Actually...when I try putting more than about 3 pics into a post, it boots me off.  I think each photo is just too big.  Plus, it's such a pretty plane, I couldn't stop taking pictures of it!
I like that underside too...
I'll post a video link in about 10 minutes if you want to see it's first tentative flights!
Dan
« Reply #8 on: August 01, 2019, 03:07:10 PM »
Behold!  It flies!  Well...it really wants to.  Now that I'm over being scared to toss it, I'll really work on trimming.
DON'T try this with your latest WNW creation.... ::) ;D
https://www.youtube.com/watch?v=4juTdFMl_No
Dan
« Reply #9 on: August 01, 2019, 04:52:08 PM »
Absolutely amazing! The look and its flying.
Offline dtomko
« Reply #10 on: August 01, 2019, 09:15:12 PM »
That is a thing of beauty!  Fantastic work and it looks so great in the air!
Drew
« Reply #11 on: August 01, 2019, 09:23:07 PM »
Really Terrific results and those last couple of flights were amazing!
« Reply #12 on: August 01, 2019, 10:09:27 PM »
Nice flights!  You're brave to try it in the tall grass with all the rigging on the plane.
Great detail for a flying model.
« Reply #13 on: August 02, 2019, 12:31:48 AM »
I would call the last flight a big success!
The light-shine-trough-wings effect is really nice and real.
Offline Radarman
« Reply #14 on: August 02, 2019, 04:46:24 AM »
Dan,
Great to see the Albatros in the air. I look forward to seeing the Halberstadt built next.
                Happy modeling and flying,
                        Kevin in Port Orchard
