Author Topic: Sopwith 'Swallow' 1:32 scale  (Read 35453 times)
Re: Sopwith 'Swallow' 1:32 scale
« Reply #105 on: September 05, 2019, 05:59:16 AM »
Oh Mike, your "sandbagger" account is gone? I was confused for a moment - welcome, Mr. Norris! ;)
Are you sure with the wood color on side panels/cockpit decking?
If I look on your picture of the first posting, it looks for me grey as the front too:
See also the top picture Windsock International Vol14/4 page 19.
That is also what the manual of my 1/48 kit says.
May be you had a Camel in mind?
It will be interesting, how the linen decals will look like, never seen that in real.
« Reply #106 on: September 05, 2019, 06:20:53 AM »
More outstanding work Mike! Looking splendid!
« Reply #107 on: September 05, 2019, 06:44:05 AM »
Super project Mike, and brave!
« Reply #108 on: September 05, 2019, 11:33:57 AM »
Outstanding so far Mike , she is shaping up wonderful  :)
Online Mike Norris (UK)
« Reply #109 on: September 05, 2019, 07:08:21 PM »
Hi Frank,
I thought I'd change to my name rather than my 'sandbagger' aka - it seems to be a trend now on some other forums I visit.
Yeah, I fell into the 'Camel' trap with the panel covering.
It's always difficult to figure out exactly what colours are evident in most WW1 monochrome photographs, but on revisiting what shots I do have, it seems pretty obvious the panels and decking were grey.
I may over spray the wood effect to give a wood texture showing through.
If not I'll strip it back and re-colour, which will be easier as the oil paints I use are water based, so can be removed with water and cotton buds (provided they haven't been sealed over).
Thanks for pointing that out, before I went too far,
« Last Edit: September 05, 2019, 10:17:55 PM by Mike Norris »
« Reply #110 on: September 05, 2019, 11:26:07 PM »
I painted wood effect on the fuselage rear panels and rear decking, but that was not correct as they should be grey.
Luckily the oil paint used is water based so I've removed the wood effect and airbrushed with 'Tamiya' ocean grey (XF82).
« Reply #111 on: September 06, 2019, 02:27:23 AM »
Excellent correction . Looks Fantastic!
« Reply #112 on: September 06, 2019, 04:09:27 AM »
The decal pre-shading has now been applied - 'Tamiya' Smoke X19.
Before the decals are applied I need to finish a few bits around the cockpit - padding, missing front to rear decking panel sections, machine guns and ammunition feeds and windshield.
« Reply #113 on: September 06, 2019, 05:43:26 AM »
Mike, that's why we doing build reports :)
I am glad that I could help, because I learnt about so many details from your build report!
« Reply #114 on: September 06, 2019, 06:21:18 AM »
The pre shading looks excellent!
Offline dtomko
« Reply #115 on: September 06, 2019, 06:59:06 AM »
Looking great, Mike!
Drew
« Reply #116 on: September 06, 2019, 10:25:01 AM »
Love it Mike !
« Reply #117 on: September 06, 2019, 08:39:55 PM »
I've used 'Milliput' two part putty to fill the gap between the resin front and rear cockpit decking panels.
Painted with 'Humbrol' leather (62) and highlighted using 'Tamiya' hull red (XF9).
Offline Gene K
« Reply #118 on: September 06, 2019, 10:28:01 PM »
A trend with what possible logical purpose (other than to confuse)?
Great project, Mike ... as usual. Your builds are always an inspiration!!
Gene K
« Reply #119 on: September 06, 2019, 11:07:29 PM »
Hi Glen,
I think some forums wan't to make things a bit more personal, rather than members using an 'aka'.
That said it's only a couple of forums I visit that seem to be edging that way,
Anyway I left 'sandbagger' in my forum name so hopefully anyone following won't get too confused,
