Author Topic: aviattic cdl decals  (Read 2096 times)
Offline minglefear
aviattic cdl decals
« on: June 20, 2019, 12:35:37 AM »
hello all I was wondering if anyone has used the above decals are they easy to use ,do they work well for large a pieces ie wings and do they easily go around the leading edge of a wing sorry question is so long I have never used these decals before any thoughts gratefully received.
Re: aviattic cdl decals
« Reply #1 on: June 20, 2019, 03:05:48 AM »
Just try it.
These decals are a bit different, but follow the manual and with a bit of experience you will get used to it.
I do not know your scale, but also in the smaller 1/48 scale I cutted decals for the whole wing in pieces. If I uses the complete lozenge sheets (independent from a kit) then I put stripes on, same structure of the fabric of the original plane. Those stripes can be handled easily.
I suggest to look around in this board in "Under Construction" and you will find a lot of reports with tips.
Offline minglefear
« Reply #2 on: June 20, 2019, 11:58:50 PM »
hi bughunter I am going to use these decals on a wingnut wings kit just wanted to know if they stretch and weather they are easy to use as I have not used them.
