Author Topic: COMPLETED 1:32 Wingnut Wings RNAS pup "Mildred H" Group Build After Build  (Read 21536 times)
Offline Iancshippee
One of my entries into this group build will be this RNAS pup, done with the livery of N6183 "Mildred H." using Pheon decals. Having just completed my first wingnut wings kit, I'm looking forward to the challenge!
Image-22 by Ian Shippee, on Flickr
Image-23 by Ian Shippee, on Flickr
Image-24 by Ian Shippee, on Flickr
Image-25 by Ian Shippee, on Flickr
« Last Edit: November 02, 2019, 11:06:00 PM by Iancshippee »
Re: 1:32 Wingnut Wings RNAS pup "Mildred H"
« Reply #1 on: February 19, 2019, 10:24:41 AM »
Looking forward to this one!
« Reply #2 on: February 19, 2019, 10:28:56 AM »
Nice choice Ian, looking forward to your progress.
Offline Gene K
« Reply #3 on: April 12, 2019, 10:17:19 AM »
Ian, you may want to try turning your flash off to eliminate the glare.
Looking forward to your build.
Gene K
« Reply #4 on: April 12, 2019, 09:54:59 PM »
Nice choice.  I would like to get a WNW Sopwith Pup sometime.
« Reply #5 on: April 13, 2019, 03:43:21 AM »
Great classic, great choice. I'm looking forward to your build.
« Reply #6 on: April 13, 2019, 11:27:22 AM »
I really like the scheme you have chosen for this , very colourful  :)
« Reply #7 on: April 15, 2019, 01:55:58 AM »
Great choice!!
Offline Iancshippee
« Reply #8 on: April 18, 2019, 10:47:20 PM »
Thanks all! Gene, glare was from unfortunately bright ceiling light. I’ve just begin on the cockpit and engine, will be posting pictures shortly!
Offline Iancshippee
« Reply #9 on: April 19, 2019, 05:56:57 AM »
Hello all! finally off and running on my RNAS Pup. I had been working rapidly on a 1:48 DC-3 for another group build, and I'm fairly content with how it came out!
IMG_3092 by Ian Shippee, on Flickr
Anyways, back to the Pup. I like to start my builds with the engine, so I eagerly tore into the Le Rhone sprue tree and got to work.
IMG_3094 by Ian Shippee, on Flickr
IMG_3097 by Ian Shippee, on Flickr
When I went to attach the valve pushrods, disaster struck! I have only just begun using Tamiya Thin, and I was caught my surprise when some wicked down my thumb while I was holding the pushrods against the cylinder heads, and I had a meltdown on some cylinders and pushrods.
IMG_3098 by Ian Shippee, on Flickr
I reached out to David at WNW and there are no spare sprues available, so working on a couple possibilities in order to proceed. Until the next post!
« Reply #10 on: April 19, 2019, 07:43:32 AM »
Sorry to see your issue with the Tamiya extra thin! It can be a problem if you aren't careful! I know because I just sealed up ALL of the pre drilled rigging holes on My Nieuport build.
Offline Iancshippee
« Reply #11 on: July 31, 2019, 04:09:40 AM »
Hello All! due to a back injury, I realized I would not be able to finish both of my builds by the deadline. I am still going to continue with this build, but it will be outside the group build. Moderators, if you care to move this thread to Under Construction, that would be totally fine with  me.
Oh, as a side note, I succeeded in finding a replacement engine and have that complete. I pressed on with the damaged one as well, and it came out looking acceptable. I'll consider keeping it for another build or using it as a stand-alone display. pictures soon!
« Reply #12 on: July 31, 2019, 05:15:37 AM »
I will be looking for your continuation in the Under Construction section. I hope you are well on your way to having your back in order!
Offline Iancshippee
« Reply #13 on: August 07, 2019, 04:02:16 AM »
Thanks Rick! Back is feeling much better. With the Albatros finished, I have resumed progress on the Pup! I did source a replacement engine, and now that it seems WNW will be producing more I will have to stock up! I mustered up even more courage and rigged the spark plug wires. very happy with the end result.
IMG_3281 by Ian Shippee, on Flickr
IMG_3282 by Ian Shippee, on Flickr
I've also completed the cockpit and have it installed in one of the fuselage halves. I apologize for the poor lighting, I've been trying lots of different approaches and I feel I can't get anything properly illuminated. Hopefully I will have a sunny day soon and can try outdoors rather than the dungeon of a house. at any rate, here's where Mildred stands at the moment.
IMG_3774 by Ian Shippee, on Flickr
« Reply #14 on: August 07, 2019, 04:04:16 AM »
Beautiful engine and the interior looks awesome in place!
