Author Topic: Completed: CSM 1/32nd Scale Nieuport 17 Early: Rene Dorme N3  (Read 72379 times)
Re: CSM 1/32nd Scale Nieuport 17 Early: Rene Dorme N3
« Reply #105 on: April 12, 2019, 09:53:26 PM »
The camouflage and weathering on the wings look good, Rick.
It's usually good to be forced to stop working on a model for a short while so you can take a step back and have a look at what you are doing. I get too rushed many times and forget to include something - a seat cushion for my Hanriot, for example.
« Reply #106 on: April 13, 2019, 12:04:28 AM »
Thanks Ken. Yes sitting back gave me the inspiration to make the small correction on the elevator control exit so it was profitable!
« Reply #107 on: April 13, 2019, 11:33:25 AM »
Really like how your top wing turned out with the weathering Rick  :) Great inspiration  ;)
« Reply #108 on: April 13, 2019, 08:20:26 PM »
Thanks T! With a little luck I should have the map box installed by tonight. Then I will finish weathering and touch ups.
« Reply #109 on: April 14, 2019, 04:53:23 AM »
Looking at those close-up shots made me think that I was looking at a real aeroplane! This really is top notch modelling Rick - absolutely brilliant.
« Reply #110 on: April 14, 2019, 07:15:31 AM »
Stephen, Thanks for the Very Generous comment  8)
Offline aliluke
« Reply #111 on: April 14, 2019, 03:27:19 PM »
This looking really impressive Rick! Beautiful airbrushing. Good on you for fixing the decal location - that takes a deep breathe to do.
Alistair
« Reply #112 on: April 14, 2019, 10:56:16 PM »
Alistair
Thanks for looking in and the comment Alistair!
Offline ermeio
« Reply #113 on: April 15, 2019, 03:03:41 AM »
impressive model!
« Reply #114 on: April 15, 2019, 03:50:50 AM »
impressive model!
Thanks ermeio. Greatly appreciated!
« Reply #115 on: April 16, 2019, 03:50:04 AM »
Today I did some Moderate Weathering with Oils and Pastels. I also applied a satin finish to the forward fuselage and semi gloss/mixed with flat finish to the fabric areas. I have added the rigging to the center wing cutout/framework. Next up is adding the clear panels then turning it into a Sesquiplane  8)
« Reply #116 on: April 16, 2019, 04:07:52 AM »
That looks super!
« Reply #117 on: April 16, 2019, 04:36:15 AM »
That looks super!
Thanks Stephen. I greatly appreciate your comment and your following of My build!
« Reply #118 on: April 16, 2019, 09:56:50 AM »
Shaping up beautifully Rick . I do like the stuttle weathering - it's perfect  :)
« Reply #119 on: April 16, 2019, 09:45:03 PM »
Thanks T! I appreciate you following along!
