Author Topic: Copper States Models N-17 late version Completed  (Read 57363 times)
Re: Copper States Models N-17 late version
« Reply #105 on: March 25, 2019, 08:53:53 AM »
 continued from page 7 , 11 more update pic's there .
Offline Kalt
« Reply #106 on: March 25, 2019, 10:06:24 AM »
Hi Guys ! Hey , thanks a bunch  8)
Made a bit more progress over the weekend , okay a fair bit of progress actual . Side panels are done , same as the prop . Land gearing and wheels are well under way with weathering still to follow . Guns are done for the most part as well as the rudder which still needs the second round of decals . All other bits are painted/weathered or waiting weathering until assembled . I tried to get the best fit possible with out the use of to much filler . Not show is the upper decking I painted the underside the shade as the framing and flooring . Tail planes is fixed place and tail skid painted up which still needs a bit more work .
Beautiful wood effect!
which colors and techniques did you use?
I have always imagined that paradise will be a kind of library.
Siempre imaginé que el paraíso sería algún tipo de biblioteca.
Jorge Luis Borges
« Reply #107 on: March 25, 2019, 09:40:10 PM »
You've made a lot of progress.  It looks great.  I like the wood panelling on the fuse sides.
« Reply #108 on: March 25, 2019, 09:53:13 PM »
Looking awesome T! The Lewis and Vickers are very well done! You are really progressing n this one!
Offline Ryan
« Reply #109 on: March 25, 2019, 10:36:55 PM »
Terri,
Clean, precise work, well done.
Ryan
Upcoming: Not sure!
« Reply #110 on: March 27, 2019, 03:35:28 AM »
The details on those machine guns is truly amazing. The colours which you have used to emphasise details are super - in fact the whole model is super! Looking forward to seeing tis one finished.
« Reply #111 on: March 27, 2019, 11:26:51 AM »
Glad that you guys are enjoying the build just as much as I'm .  :) Thanks for your support ! Was going to start airbrushing the primer for the fuselage and top wing , but it's raining right now , nothing like those spring showers to freshen things up  and hamper my plans . Should be able to start tomorrow or the next day ...maybe  :'(
Kalt , I did the side panels in this order .
1. base primer  Tamiya wooden deck tan . Let this dry for at least 12 hours .
2. I used two different shades of artist pencil crayons alternating between the two shade skipping the odd space so it didn't look uniforum .
3. I then used a q-tip and rub the whole surface in circle .
4. I thinned Tamiya smoke and sprayed that along the wing root area and inspection hatches until I was pleased with the  effect . Then I made one pass along all the edges of the panels .
5. Next many , many thin coats of tamiya clear yellow was built up . Set side for 24 hours to dry .
6. A wash was then applied using Flory Models line ( brown ) and let this dry . Wipe off the excess
7. This was all sealed with Testors dull coat to dull it and blend it all together .
« Reply #112 on: March 28, 2019, 12:16:16 PM »
Success was had today !  By the end of the day the weather started to behave and was able to do a bit of airbrushing . Prime coat is on  :) Will let this dry for 24 hours , then comes the Vallejo Metal coat - white aluminum . Also got a wash on the wheels and undercarriage . Still need to choose a scheme and find rigging manitrail , wasn't able to get easyline .
What size of mono line are you guys using ? I have 0.23mm which is way to big ! In the cockpit I used smoke thread and stretched spuce and that didn't go very well for me .
« Reply #113 on: March 28, 2019, 12:16:55 PM »
Offline Kalt
« Reply #114 on: March 28, 2019, 02:07:24 PM »
Thanks Terri!, I will try to use your technique
Jorge Luis Borges
« Reply #115 on: March 28, 2019, 09:49:04 PM »
"What size of mono line are you guys using ?"
I use 0.005" (0.127 mm) for most rigging, which is 0.16" in full scale, and 0.007" (0.178 mm) sometimes.
« Reply #116 on: March 29, 2019, 12:33:26 PM »
Your welcome Kalt  :) Thanks Ken , this gives me something to go by now .
Got paint ? ..... Yup !
« Reply #117 on: March 29, 2019, 12:34:15 PM »
Offline Edo
« Reply #118 on: March 29, 2019, 03:41:46 PM »
so neat Terri!
besutiful work indeed!
ciao
edo
« Reply #119 on: March 29, 2019, 09:58:07 PM »
Beautiful smooth Aluminum finish Terri!
