Author Topic: 1:16 Sopwith Camel by Model Airways  (Read 6001 times)
Offline Garage21
« on: January 23, 2019, 09:49:20 AM »
My intent is to use the wooden pieces in the kit but replace all the pot metal castings with scratch-built pieces in brass, aluminum and copper.  Also will be building a 1:8 scale Clerget engine to stand next to the plane.
This is my first non-classic car model so I'm pretty excited.
Offline aliluke
Re: 1:16 Sopwith Camel by Model Airways
« Reply #1 on: January 27, 2019, 03:08:05 PM »
Hi Garage 21
I look forward to this big scale build and your ambitions for it. Keep the posts coming.
Alistair
« Reply #2 on: January 27, 2019, 11:20:51 PM »
Looking forward to your progress on both kits.  Both nice and big!
Offline Garage21
« Reply #3 on: January 28, 2019, 02:14:01 AM »
Before I start building the Camel, I've got to fabricate the pieces and parts that I'm replacing form the original kit.  I figured I'd start with the turnbuckles since I need to fabricate over 100 of these things.  It took me a few tries, but I feel like I'm on the right track now.
[img width= height=]https://www.bellateq.com/g21photos/camel/012323[/img]
Online lone modeller
« Reply #4 on: January 28, 2019, 04:50:06 AM »
Those turnbuckles look super - if the rest of the build is to this standard you will have a museum quality model at the end.
Offline Garage21
« Reply #5 on: January 28, 2019, 05:52:57 AM »
Thank you Aliluke.  All of the metal bits that came in the kit are going to be scratch built from brass, aluminum and copper.  The engine will be scratch built and a second, 1:8 scale engine, will be built to display next to the plane.
If this goes like the rest of my projects, I'm guessing 8 months to a year until completion.
Stay tuned.
Andy.
Offline acewwi
« Reply #6 on: January 28, 2019, 06:07:32 AM »
Hi Andy,
why you do not try this material http://www.gaspatchmodels.com/products/resin-turnbuckles-type-c-1-16.html
Spyros
Offline Garage21
« Reply #7 on: January 28, 2019, 07:07:35 AM »
Hi Spyros - I had thought about using those, but the actual units on the actual plane would have been made out of metal so I wanted to go with metal.  I know you can paint resin to look like metal, but the brass turnbuckles with the copper safety wire looks fantastic and you can't really get the proper look with paint on resin.
Ultimately, I wanted to get the look of actual metal against the wooden wings as I think that will be striking.
Andy.
Offline BillB
« Reply #8 on: January 28, 2019, 09:41:26 AM »
Do you plan to leave the metal natural, paint it, or use a chemical blackener?
Chemically blackened with the safety wire added afterwards would really be eye catching.
- BillB
Offline Garage21
« Reply #9 on: January 28, 2019, 10:36:48 AM »
I haven't really decided yet Bill.  I definitely will not be painting the turnbuckles.  More than likely they'll be blackened with a light acid dip and then the copper safety wire will be left shiny.
What do you recommend?
Offline BillB
« Reply #10 on: January 28, 2019, 11:17:28 AM »
Micro-Mark has a wide variety of chemical treatments for metals, and Birchwood Casey has several, including an aluminum blackener.
For years I've used A-West Blacken-It, available from Walthers (though out of stock at the moment), and industrial supply stores, like McMaster-Carr, have carried blackening solutions for years, but the last I looked all they had was essentially black paint.  Some of the chemicals formerly used were a bit too toxic for today's consumer protection advocates.
A little Googling will no doubt uncover other sources.
BillB
« Reply #11 on: January 28, 2019, 12:58:34 PM »
Amazing work on those buckles! They should certainly look authentic!!
Offline aliluke
« Reply #12 on: January 28, 2019, 04:14:04 PM »
Turnbuckles look great. Just some thoughts...
The turnbuckle will only be at one end of the line the other end is fixed - a 100 seems a lot - you might be double counting?
Snipes have no visible turnbuckles at all - there is good discussion here about this under the rigging section.
See photo below of a turnbuckle on a Pup (I think). Very small and bright steel in colour.
If you are blackening, Birchwood Casey, as recommended, is the best I've ever used - and I tried many - but that was for ship models.
Alistair
Offline Garage21
« Reply #13 on: January 28, 2019, 11:09:41 PM »
Aliluke - I was including the clevises in the count with the turnbuckles since those have to be fabricated also.
The clevises will be much easier to fabricate though.
Offline Garage21
« Reply #14 on: February 02, 2019, 08:14:21 AM »
So I went through all the plans and confirmed that I was going to need about 100 of the double-eye turnbuckles.  I got them all fabricated (finally).  I need to sand, shape and polish as well as drill out the center hole and run the safety wire, but they're "done enough" for now.
12 hours over 10 days is the answer to how long these took.
*** COULD SOMEONE PLEASE REMIND ME HOW TO EMBED A PICTURE IN THESE POSTS.  I DID IT ONCE AND NOW I FORGOT HOW I DID IT."
G21
« Last Edit: February 02, 2019, 08:19:43 AM by Garage21 »
