Author Topic: 1/32 'Skeletal' Fokker Dr. I  (Read 22703 times)
Offline kkarlsen
Re: 1/32 'Skeletal' Fokker Dr. I
« Reply #15 on: January 14, 2019, 07:17:36 PM »
Thank's Guy's, your too kind. I'm happy you like the build  ;)
I've had a break from this project (just needed to refill my mojo, I guess)
Some progress on the wings, detailing and getting an acceptable finish before painting.
Now I've started on the wood grain, keeping it down, to simulate light veneer/wood and to avoid it to become 'mahogany-ish'.
I intend to us Uschi von der Rosten veneer decals on the leading edges...
Haven't tried wood grain decals before, any thoughts, good or avoid?
Cheers: Kent
« Last Edit: January 14, 2019, 09:51:01 PM by kkarlsen »
« Reply #16 on: January 16, 2019, 04:08:01 AM »
I cannot comment on the use of wood grain transfers as I have never used them. However I really do like your wings - the structures are superb. A wonderful build in the making.
« Reply #17 on: January 16, 2019, 05:28:25 PM »
Hello, Kent,
I have used them on my what-if model and was quite satisfied (see here:https://forum.ww1aircraftmodels.com/index.php?topic=8729.msg162424#msg162424). They were easy to use and I did not have and problems with microscale decal set and soft. However, I have to say that the standard decals are quite pixelated on closer inspection. With your high carat model I would at most use the new decals from Uschi, where you can't see any pixels anymore, or better work with oil paints, with which you can imitate a much more discreet wood structure.
Bye,
Offline kkarlsen
« Reply #18 on: January 16, 2019, 08:08:21 PM »
Thank you for your input Manni.
I have tried to apply the decals and you are right, they are 'coarse' and a tad too reddish.
Now I wish I wouldn't have used them
I will 'contemplate' on this for a few days before deciding what  to do...
Cheers: Kent
Offline kkarlsen
« Reply #19 on: March 29, 2019, 01:52:33 AM »
A little update on the 'Fokker'...
Oberursel engine ready for installation
Some of the instruments are done.
Parts are beginning to come together.
Thanks for looking: Kent
« Reply #20 on: March 29, 2019, 02:40:36 AM »
Most Impressive! every single part looks AWESOME!
« Reply #21 on: March 29, 2019, 03:43:55 AM »
I agrre with Rick - this is superb modelling.
What did you make the fuselage frames from? And what was your source of turnbuckles?
Offline kkarlsen
« Reply #22 on: March 29, 2019, 05:28:18 AM »
Thank you Gent's, appreciate it.
Fuselage frame is done with 0,8 mm styrene rod and the turnbuckles are Radu's photoetch.
http://www.radubstore.com/index.php?main_page=product_info&cPath=2_68&products_id=403
Cheers: Kent
Offline kkarlsen
« Reply #23 on: April 01, 2019, 05:01:22 AM »
Wood grain on the wings are done, continuing with some of the control cables...
That's it for now: Kent
« Reply #24 on: April 01, 2019, 05:13:15 AM »
Wood grain and cables look Brilliant!
« Reply #25 on: April 01, 2019, 04:20:54 PM »
I am out of words! Beautiful in every aspect. THe wood and all the strings....great.
Bye,
« Reply #26 on: April 02, 2019, 04:13:55 AM »
What excellent workmanship. The wood grain looks real!
Offline UFAG
« Reply #27 on: June 23, 2019, 09:29:53 PM »
its been said before...but..Brilliant!
Offline kkarlsen
« Reply #28 on: August 16, 2019, 06:54:14 PM »
Suddenly finishing this one has become more interesting, did something just happen?
Well the progress has been painstakingly slow, but her we are...
The rib bracing tapes have been added using Tamiya tape.
I'm still struggling with the many details of the Cockpit, but it's getting there...
Cheers: Kent
« Reply #29 on: August 16, 2019, 10:33:17 PM »
Simply Spectacular work! The burnished metal is incredible!
