Author Topic: "...an out of date Pfalz..."  (Read 6960 times)
Online Brad Cancian
    • Brad's Models
« on: December 20, 2018, 07:06:48 AM »
Hello everyone,
Here are some pictures of my latest completion, the Encore (Roden) 1/72 Pfalz D.III. This is their “Blue Max” boxing, which depicts the aircraft flown by Ltn Bruno Stachel (George Peppard) in the 1966 movie “The Blue Max”. If you haven’t seen this aviation classic, I strongly recommend it.
The kit was built with the addition of the PART photo-etched set. The kit itself is a bit rough around the edges, and requires a bit of refinement, but it looks like a Pfalz. The Lozenge decal is from Aviatik, and presents some better colours than those included in the kit. These decals are excellent; translucent (which makes them good for pre-shading), very thin, durable, and able to be contorted across compound curves (mostly). This was especially useful given the compound curves of the fuselage; I didn’t get it perfect but I was happy enough in the end. Rigging is from Uschi brand elastic.
I didn’t go for a ‘movie perfect’ model; rather, I built is as a ‘normal’ Pfalz (though I did mix up the D.III and D.IIIa parts, deliberately), with the markings broadly representative of the movie aircraft.
Here’s some pics of the model:
I also decided it would be cool to mount this one to a more appropriate base:
I added a pilot from the spares box, with a rather stern looking head from an Airfix BE-2C crewman, and a scarf made from foil. I tried to replicate a spinning propeller, but nothing I tried or looked at really looked convincing, so I simply made a prop-less spinner from scrap plastic.
Overall this was a fun little build.  Good hunting, herr Leutnant!
Offline Jamo
  • Wellington, NZ
    • My Smugmug album
Re: "...an out of date Pfalz..."
« Reply #1 on: December 20, 2018, 07:21:33 AM »
Love the whole display! Beautifully executed. Thanks for sharing Brad
Happy Modelling
James Fahey
« Reply #2 on: December 20, 2018, 07:43:27 AM »
Nicely done Brad, the second Base with the Blue Max incorporated is brilliant. Ltn. Stachel is no doubt proud!
« Reply #3 on: December 20, 2018, 08:44:40 AM »
Outstanding Brad! A wonderful model from my favourite movie! The in flight display is an imaginative and striking scene.
Many thanks for sharing this with us
cheers
« Reply #4 on: December 20, 2018, 09:53:00 AM »
Awesome as always Brad! Your work in 1/72nd is second to none. Love the Movie Scheme and display.
« Reply #5 on: December 20, 2018, 10:04:17 AM »
Big Ditto to my Amigo's comments !!
« Last Edit: December 25, 2018, 07:21:37 AM by dr 1 ace »
Offline petrov27
« Reply #6 on: December 20, 2018, 11:43:51 AM »
wow - that is sharp - well done! Great base and presentation as well
-Patrick
« Reply #7 on: December 20, 2018, 12:38:50 PM »
Excellent build and presentation.  Congratulations Brad, I thought it was their 1/32 kit at first.
« Reply #8 on: December 20, 2018, 02:13:43 PM »
Beautifully done, Brad, with your usual superb artistry.
Online Brad Cancian
    • Brad's Models
« Reply #9 on: December 20, 2018, 05:30:00 PM »
Many thanks gents!   ;D
« Reply #10 on: December 20, 2018, 05:55:21 PM »
Beautiful model and an outstanding presentation. Perfect.
Bye,
« Reply #11 on: December 20, 2018, 06:40:21 PM »
One word...
Superb!
vB  ;)
« Reply #12 on: December 21, 2018, 04:03:20 AM »
That’s outstanding Brad!
Love the lozenge, no idea how you got that around the fuselage! The pilot is excellent too! Where did you get him?
Online Brad Cancian
    • Brad's Models
« Reply #13 on: December 21, 2018, 08:38:34 AM »
Hi Guy - the fuselage lozenge was cut using a template before application. The Encore kit comes with some pre-cut lozenge for each fuselage half, but I wanted a complete wrap-around look, given the actual aircraft had the pattern painted. I used the Encore lozenge as a starting point for making my own template from masking tape, which I tested and adjusted a number of times to fit. I took that template and used it as a template for both the paint masking (given the lozenge decals from Aviattic are translucent, they need a light base coat), and for cutting the decal itself. That meant the decal and paint mask matched, so there would (in theory) be no overlapping. It was 90% successful; there were still some overlaps, and still some wrinkles, but I managed to get some of them out by careful cutting and application of decal softener.
A picture of some of the masks / templates I used is attached.
The pilot body I had in the spares box (not sure exactly which kit it came from, but I recollect it came from an aircrew set somewhere), the head came from one of the two pilots included in the Airfix BE-2C kit.
Hopefully this helps?
BC
Offline ModelCellar
« Reply #14 on: December 21, 2018, 10:15:50 AM »
Brad,
WOW, that is really, REALLY COOL.  First the airplane is AMAZING for 1/72 scale.  And then I like what you did with the base - fantastic presentation.
