Author Topic: My builds so far  (Read 7558 times)
Offline Ian from Doncaster
My builds so far
« on: April 20, 2012, 08:10:29 PM »
Let's hope the photo links work - here are my WWI builds to date, starting with the WNW LVG C.VI and the Revell 1:72 EIII.
Offline ta152c
  • My threads are doing iron man numbers
Re: My builds so far
« Reply #1 on: April 20, 2012, 08:21:01 PM »
Good work there, LVG looks very neat and the E.III is well-finished.
Regards :)
"I hope he burned all the way down" - Mannock on hearing of the death of Manfred Von Richthofen, 1918.
Offline Galloway
« Reply #2 on: April 20, 2012, 09:49:56 PM »
Ian,
  Very Nice .... That little Revell E.III sure brings back memories! Thanks for posting..........
   Ken
"Slàinte mhòr agad!"
« Reply #3 on: April 21, 2012, 01:53:54 AM »
Ian, really nice! The WNW LVG looks great. I also have a soft spot for that Old Revelle kit of the EIII. Must have built dozens in my formative years 8)
Offline keith_christie
« Reply #4 on: April 21, 2012, 02:03:07 AM »
Hello Ian,
Your LVG looks very nice indeed and that EIII must be tiny....
Best Regards
Keith
« Reply #5 on: April 21, 2012, 03:07:40 AM »
Glad to see these fantastic builds again, Ian.  I'm still amazed at the cowling and metal panels on the Eindecker.  How you got that effect in such a tiny scale is beyond me.
« Reply #6 on: April 21, 2012, 03:11:06 AM »
Nice cross section of the new and the old!!
« Reply #7 on: April 21, 2012, 03:35:12 AM »
Here are some more pics:
Revell 1:72 E.III
WNW LVG C.VI
Airfix 1:72 Albie DVa
WNW RFC Pup
Eduard 1:48 E.III
« Reply #8 on: April 21, 2012, 03:39:27 AM »
Hi Bud, the cowling is simply two slightly different metallic colours sprayed one over the other, then the top coat gently worked back with fine micromesh.
For my next E.III (WNW pleaseeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee....) I may try using metalcote and polishing each "machined" circle individually.  I'll do a trial first.
« Reply #9 on: April 21, 2012, 03:50:14 AM »
Thanks for the exlpanation, Ian.  And thank you for posting more of your beautiful models.
« Last Edit: April 21, 2012, 09:48:34 AM by coyotemagic »
« Reply #10 on: April 21, 2012, 08:05:52 AM »
Ian, the swirl pattern on that cowling is indeed excellent. Wish I had seen this before I painted my ammo cans on my DR1 build this morning :-[
Offline Whiteknuckles
« Reply #11 on: April 21, 2012, 11:32:50 AM »
Lovely models Ian - thanks for sharing
Eternal Apprentice
« Reply #12 on: April 21, 2012, 06:21:40 PM »
Bud, Rick, further to the explanation above, I don't sand off the first metallic layer.  This leaves a slightly granular surface in which the second colour settles.  Sanding that colour reveals the high points of the first layer, with the second layer showing in the low points, resulting in the blotchy effect.
Offline Pete Nottingham
« Reply #13 on: April 21, 2012, 06:55:24 PM »
Thanks for sharing Ian, beautiful models.
Pete.
« Reply #14 on: April 22, 2012, 01:54:49 AM »
All real beauties Ian, and in particular, I like that WNW LVG C.VI. I tip my hat to all you fellows that build, let alone rig anything in 1/72 scale.
