Author Topic: Nice plastic nuts n bolts from Meng  (Read 2046 times)
Offline kornbeef
« on: June 16, 2015, 03:17:57 AM »
Guys for your info.
Meng do a nice  range of plastic Nuts and bolts and a few conical rivets too with and without washers in about 6 different sets.
The small sets range from 0.8mm upto 1.7mm, the large from 1.8mm to 2.5mm and you get more than plenty of each on a sheet of snap off tabs.
thers also sheets of allen socket heads and  recessed nuts you could drill the centres through.
Very innovative
Hannants have them in stock, just search under nuts. or bolts... ::)
Keith
Re: Nice plastic nuts n bolts from Meng
« Reply #1 on: June 16, 2015, 07:49:01 AM »
Thanks Keith for the info, I am always on the lookout for nuts and bolts for my scratch builds.
« Reply #2 on: June 16, 2015, 09:44:48 PM »
i saw those on ebay but it is hard to judge if they would lookk good or rather in scale on aircraft builds . so keith are they mainly better suited to 1/32 or could they also be used on 1/48?
« Reply #3 on: June 16, 2015, 11:08:12 PM »
.8mm works out to ~38mm in 1:48; that's a very large fastener even on an aircraft engine. About the largest fastener seen on the Merc D.III is 33mm (cylinder skirts to crankcase). 10, 14mm & 17mm are sort of typical sizes for general nuts and bolts -- the kind of things used in structures and so on.
Offline kornbeef
« Reply #4 on: June 17, 2015, 02:25:39 AM »
1/32 I would say, not so good for smaller scales. The 0.8's look around WNW Merc case nut size.
« Reply #5 on: June 17, 2015, 03:40:23 AM »
case nuts hex size were 17mm (thanks Bertl) which works out to ~.5mm…
Offline kornbeef
« Reply #6 on: June 17, 2015, 02:53:51 PM »
Well I'm not going to be anal about it but they look about the same as WNW's size wise.  ::)
When your eyes get as poor as mine and your fingers are like sausages they just become pips of plastic any smaller.  ;D
K
