Author Topic: Roden Nieuport 24 BIS SPA. 124 1/32nd, CSM Nieuport XVII N124 1/32nd  (Read 59888 times)
Re: Roden Nieuport 24 BIS SPA. 124 1/32nd, CSM Nieuport XVII N124 1/32nd
« Reply #45 on: January 18, 2019, 06:48:51 AM »
Nice interiors, all coming fine.
« Reply #46 on: January 18, 2019, 08:12:02 AM »
Very nice progress on the fuselage, Rick. i am pretty much on the same point as you are and went through equal experiences regarding the side panels. That’s one of the trickier aeras with this kit I think. Great eye for the detail when it comes to the holes for the elevator control lines!
Best regards
« Reply #47 on: January 18, 2019, 09:59:08 AM »
Side panels attached as well as the upper decking. Some filling will be required but I am sure it is my construction not the kit. I have learned some things I will do differently on the next one  8)
Offline Edgar
« Reply #48 on: January 18, 2019, 06:41:09 PM »
Hey Richard, looking very good, and great fit of the upper cowl)
just do not overfill side panels, they should stick out a bit, as they were plywood "cheeks"
« Reply #49 on: January 19, 2019, 05:08:09 AM »
Catching up again Rick: the wood finish in the cockpit is truly first class. What a pity most of the detail will not be easily seen.... - could you have left the side panels off so that we could see it more clearly?
« Reply #50 on: January 19, 2019, 09:15:43 AM »
Thanks Edgar! I will be careful not to overfill  the join of the forward and rear fuselage  ;D
Thanks Stephen! As always I appreciate your comments. Yes I believe the panels can/could be left off , actually seems to be designed to accommodate that. On the other hand a lot more details would need to be added. I don't like leaving panels open as I appreciate the closed up lines of most WW1 aircraft. Just My preference.
« Reply #51 on: January 26, 2019, 10:49:35 AM »
I have progressed on the Nieuport 17. I added some PE to the aileron control exit ports that I had re positioned earlier. I also filled, sanded, and re scribed the front/rear fuselage join. I then sprayed all major surfaces with Model Master Gull Grey as a primer prior to some subtle pre shading.
« Reply #52 on: January 27, 2019, 05:53:35 AM »
Coming on nicely Rick!
« Reply #53 on: January 27, 2019, 07:00:12 AM »
Looking good Rick, too bad the beautiful office is mostly covered now.  Looking forward to your progress on both.
« Reply #54 on: January 27, 2019, 12:15:09 PM »
Thanks for looking in and commenting Guy. Greatly appreciated!
Thanks Juan. As always I appreciate your support!!
Offline aliluke
« Reply #55 on: January 27, 2019, 03:05:56 PM »
Hi Rick
Just catching up with your log - looking great and I'm looking forward to seeing more! My Nieuport build is going to be a while away so I can enjoy spying on everyone elses!
Alistair
« Reply #56 on: January 28, 2019, 01:03:04 PM »
Hi Rick
Alistair
Thanks Alistair. I appreciate your comments!
« Reply #57 on: January 28, 2019, 05:07:45 PM »
Great progress on the fuselage Rick. You installed the forward panels perfectly. I am keen on seeing this one finished! Do you already know what you are going to use for the aluminium dope?
Best regards
« Reply #58 on: January 29, 2019, 01:01:14 AM »
Best regards
Thanks for the comment Andreas. I have an Old Tin of XTRA color 252 Weiss Aluminum that I am going to use. The forward upper deck is already done in this color.
Offline krow113
« Reply #59 on: January 29, 2019, 03:12:04 AM »
Going well!
