Author Topic: Hansa Brandenburg W.29 1:32 Wingnut Wings  (Read 23868 times)
Re: Hansa Brandenburg W.29 1:32 Wingnut Wings
« Reply #15 on: September 15, 2018, 08:39:28 PM »
Here's more information:
When researching the colour schemes and finish of the Hansa-Brandenburg W.29 I found that as usual, there are different interpretations available.  The official standards laid down during WW1 for the finishes to be applied to aircraft of the German Naval Air Service were dependent on the time of issue.
General Colour Schemes
Order ’B Nr F5952’ dated 28th March 1917:
Printed hexagonal fabric (hexagonal grey-brown, grey-blue and grey-violet) was to be applied to all upper surfaces (wing, fuselage, floats, tailplane and elevator). All side surfaces (fuselage, floats, rudder, tail fin and struts) were to be painted Grey-Blue. The underside surfaces to be a light Grey colour, but the underside surfaces of the wing (and presumably tail plane) were to be left as Clear Doped Linen (CDL). The painted surfaces were to be of a matt (flat) finish.
Later orders dated April 1918:
Printed hexagonal fabric (hexagonal grey-violet) was to be applied to all upper surfaces (wing, fuselage, floats, tailplane and elevator). All side surfaces (fuselage, floats, rudder, tail fin and struts) were to be painted Grey-Blue. The underside surfaces to be a light Blue or left as Clear Doped Linen (CDL). The painted surfaces were to be of a matt (flat) finish. There were caveats that stated for the duration of the war, aircraft surfaces (not those fabric covered) could be
painted with acid free tar based varnish. Additionally all naval G- and R– types should either be painted or have printed fabric applied, both of which should be three colour hexagonal.
References:
Osprey Aircraft of the Aces - Naval Aces of World War 1 (Part 2) by Jon Guttman:
The colour profiles shown for this aircraft have all upper surfaces (except the engine/cockpit areas) and including the two floats, in three colour hexagonal, undersides of the wing,
fuselage, tailplane and elevator as CDL and white on the rudder/fin. All side surfaces, including the two floats as being Grey-Blue.
Windsock Data File No.55 - Brandenburg W.29 by Peter M Grosz:
The colour profiles shown for this aircraft, particularly W.29 No.2532, appear to have all upper surfaces (except the engine/cockpit areas) and including the two floats, in three colour hexagonal, undersides of the wing and tailplane as CDL and white on the rudder/fin. All side surfaces as being Grey-Blue.
Fabric application.
Generally the patterned fabric was applied to the various surfaces as follows:
Wings - Length of the bolt of fabric applied chord wise (leading edge to trailing edge).
Ailerons and elevator - Length of the bolt of fabric applied span wise (left to right).
Tailplane - Length of the bolt of fabric applied span wise (left to right) although the Wingnut
decals have it as for the wings (chord wise).
Fuselage - Length of the bolt of fabric applied chord wise (front to rear).
Offline ktrembacz
    • My instagram profile »
« Reply #16 on: October 09, 2018, 11:57:04 PM »
Here's more information: [...]
What a research! Thank you very much for those informations. I really appreciate it and will definitely use this knowledge ::)
Follow me on instagram: https://www.instagram.com/ktrembacz/
« Reply #17 on: October 10, 2018, 12:02:27 AM »
Beautiful work on the interior, Kamil!  Very nice weathering.
Offline ktrembacz
« Reply #18 on: October 31, 2018, 10:39:13 PM »
Thanks!
I've spent last 2 months making engine. I made several element from scratch. I also used Taurus Models spark plugs and springs. I'm satisfied with final effect but I know that it could be better. What do you think?
« Reply #19 on: October 31, 2018, 11:45:49 PM »
Well worth the time and effort, truly beautiful and a mini model onto itself.
« Reply #20 on: October 31, 2018, 11:57:20 PM »
Magnificent work on the engine, truly outstanding. This is destined to be a real winner, the detailing is in it's own league!
« Reply #21 on: November 01, 2018, 01:55:09 AM »
Hi Kamil,
Having completed my model, I know just how much effort and patience is needed to produce such an engine as you have.
Congratulations
Offline Ryan
« Reply #22 on: November 01, 2018, 01:59:26 AM »
This is beyond my skill level, splendid work.
Ryan
Upcoming: Not sure!
« Reply #23 on: November 01, 2018, 03:24:30 AM »
Sorry to be late to the party but......well what do I write! This is so realistic that I thought that I was looking at photographs of a modern replica being built! It was the tweezers which made me realise that it is a model!!
Brilliant work.
« Reply #24 on: November 01, 2018, 07:44:44 AM »
Gorgeous Engine!
Offline aliluke
« Reply #25 on: November 01, 2018, 03:26:41 PM »
Stunning work - a beautiful engine. My only comment being that those exhaust pipes could be reamed out a little further? A tiny detail in a beautiful piece of modelling.
Alistair
Offline KevTheModeller
« Reply #26 on: November 02, 2018, 08:29:56 AM »
Your attention to detail is amazing, excellent work I'm watching with great interest.
Kev
Offline ktrembacz
« Reply #27 on: November 09, 2018, 10:19:18 PM »
Thanks everyone for opinions!
Sure... As Wingnut, this model is quite demanding :)
 ;D
You're right. They are a little too thick. I grinded it but not enough. I'll try to improve it but it'll very hard, becouse this pipes are delicate.
Hansa's interior is closed now. I'm working with putty and I'm preparing to painting wings and tailplane. Special thanks to sandbagger for references again!
A few pics from my workshop:
« Reply #28 on: November 09, 2018, 11:28:51 PM »
The engine and interior look stunning in place! Beautiful work all around.
Offline ktrembacz
« Reply #29 on: November 28, 2018, 07:22:50 PM »
Slow progress... I had a problem with filling the fuselage but it's close to be done.
First fitting after surfacer:
And i started masking wings and stabilizers:
If you see sth wrong please tell me before it will be to late :D
