Author Topic: Siemens-Schuckert D.III, Eduard 1/48 Update 23.9.2018 Rigging  (Read 21887 times)
« Last Edit: May 31, 2022, 01:21:15 AM by Bughunter »
Re: Siemens & Halske Sh.III, Eduard 1/48
« Reply #1 on: July 30, 2018, 08:02:36 AM »
Ah, here you are now. The answer to the question "what comes next" came faster than expected. I really like what you did with the engine. Did you already decide what color sheme you'll do?
« Reply #2 on: July 30, 2018, 08:25:46 AM »
Not resting on your Laurels I see  ;D Your engine looks Stunning in spite of any issues you had! Your usual awesome work and I am really looking forward to the rest of the build!
« Reply #3 on: July 30, 2018, 08:56:10 PM »
Great work on the engine Frank, I look forward to seeing the rest of the plane glued behind it!
Antonio
Offline krow113
« Reply #4 on: July 31, 2018, 03:31:46 AM »
Great engine work.
I'll watch for the finish.
Siemens & Halske Sh.III, Eduard 1/48 Update 30.7.2018
« Reply #5 on: July 31, 2018, 03:44:07 AM »
« Last Edit: May 31, 2022, 01:21:24 AM by Bughunter »
Offline krow113
« Reply #6 on: July 31, 2018, 04:33:44 AM »
Wow!
Prop props for sure!
Online lcarroll
    That's a beautiful prop Frank. I did one for the 1:32 Roden D.III several years ago and failed on the first try however I was able to succeed by doing two 2 blade props and then joining them, I think not as efficient as your method with four blades from the beginning of the construction. The grain and veneer on this one look great!
     Being in the larger scale I was able to use 8 layers of veneer, it took a lot more time then the standard props I usually produce.
    As always your work is exceptional, and I'll look forward to following your progress on this beauty, one of my three top favorite WW.I aircraft.
Brilliant work on the prop Frank! I am in AWE!
Magnificent work on this project!
There's a 4 blade Wotan prop at the Auckland War Memorial in NZ.
It features a Wotan logo on each blade:
Wow Frank, another beauty underway.....  That four blade prop looks outstanding.
Offline pustota
I realy love you wooden works skills! Bravo on the prop.
Offline petrov27
Very nice work there - the prop is brilliant!
Great choice in scheme - I did the same Dembrowsky machine in 1/32 and it looks very nice when complete
-Patrick
Brilliant engine and propeller, I'm looking forward to the Siemens build.
Offline smperry
Most excellent work. one of the prettiest wooden props I have seen.
Can you say more about the wood you used? What kind is it? What thickness? Where can such pieces be had?
I have an old Eduard SSW D.III kit I have been looking forward to doing something with. Built one years ago and it was a bear to get through. Louvers come to mind as something of a nightmare. A stunning wooden prop may well take eyes off other parts.
sp
