Author Topic: Roland C.II 1/32  (Read 21878 times)
Re: Roland C.II 1/32
« Reply #60 on: May 07, 2018, 06:43:15 AM »
Some additional things I can tell you, if you don't mind, mostly geared to airbrushing.  Two important things you'll want are Future and ammonia based glass cleaner.
Thinning your paints with Future makes for more durable finishes.  I usually get them to a nice creamy texture like latex house paint.  They stay stable like this for a while, and I keep them in little containers.
You'll want to make an airbrush cleaner and flow enhancer with a mix of 50/50 glass cleaner and water in a small bottle.  Some people use purified water, but I've never had trouble using tap water.  A couple drops of glycerine or liquid dish washing soap will reduce surface tension and help to prevent dry-tip.   But to be totally honest I've never completely escaped dry-tip.
Acrylic tube paints don't brush as nicely as enamels.  But...  They make great, quick drying washes.  All of the color on my Mercedes D.III engine on my Alby D.V build, except the silver and brass base coats and wires, is done with acrylic washes of various thicknesses thinned with water.
HTH,
Gaz
Offline RLWP
  • Bodger
« Reply #61 on: December 09, 2019, 06:21:55 AM »
May 2018 - not so long ago for this resurrection...
« Reply #62 on: December 10, 2019, 12:25:29 AM »
Another Phoenix rising from the Ashes? Looks Terrific!
« Reply #63 on: December 10, 2019, 12:09:01 PM »
Cool , half done already ! Why is it in a vice for by the way ? And I can't help notice your trains . Are this built by you ? I know ...I know so many questions  ;)
Offline RLWP
  • Bodger
« Reply #64 on: December 10, 2019, 07:07:02 PM »
I should have done a lot more work getting the upper wing to fit correctly before getting carried away with a spray can. I have fettled the joint as much as I dare - the vice is doing the rest
Those trains - no. They belonged to the father of the neighbour of a friend. She was having trouble moving them on, so I took them. I'm trying to decide what to do with them.
I do model railways though. When I go quiet here it is usually because I have shifted focus to doing that (and vice versa)
« Reply #65 on: December 12, 2019, 12:15:43 PM »
Done that myself getting carried away , still do actually . Thanks for explanation for the trains . Your builds are really small , but packed with detail . Awesome !
Offline RLWP
  • Bodger
« Reply #66 on: February 17, 2020, 05:16:22 AM »
OK, kicked this one across the line:
I really should have paid more attention to the wing/fuselage joints before doing the ambitious rattle can spray job. I have been fighting 'touching up' the paint ever since
Otherwise, she's OK. I'm particularly pleased with the long 'turnbuckles'
« Reply #67 on: February 17, 2020, 05:30:02 AM »
Excellent finish to this one Richard! I also like your Long Turnbuckles!
Offline RLWP
  • Bodger
« Reply #68 on: February 17, 2020, 05:31:37 AM »
Maybe I'll twist another up to show how I did it
« Reply #69 on: February 17, 2020, 08:20:55 AM »
Nice to see this one cross the finish line . Excellent work !
Offline RLWP
  • Bodger
« Reply #70 on: February 17, 2020, 09:06:43 AM »
Thanks Terri. As a model, it's OK, I was hoping it would turn out better
I must admit, it looks good in the pictures
« Reply #71 on: February 17, 2020, 11:08:17 PM »
Nicely done, Richard.  It appears one can actually see inside the fuse through those large windows.
