Author Topic: Eduard's 1/48 Sopwith Camel F.1 - the first to score N6347  (Read 16039 times)
Re: Eduard's 1/48 Sopwith Camel F.1 - the first to score N6347
« Reply #45 on: April 18, 2018, 09:09:33 PM »
Excellent added details. It took a minute for me to remember this is the 1/48th Eduard kit!
« Reply #46 on: April 19, 2018, 02:19:42 AM »
Actually great progress. A masterpiece in the making!
Borsos
Offline Halus
« Reply #47 on: April 19, 2018, 10:27:47 AM »
Thank you GazzaS, RAGIII, and Borsos.
Manni, thanks I think, but if you are referring to the home made turnbuckle photos, that is Frank's (Bughunter) work.
regards,
Jack
Offline Halus
« Reply #48 on: June 07, 2018, 09:52:47 AM »
Sopwith Camel is still on the bench, but have missed a few days here and there of getting myself to sit down ...
Got the struts sorted out, but man it's true as someone stated on another forum - it's like trying to balance a ruler on four free standing pencils.   The cabane struts are fixed directly onto the fuselage, different from Eduard's design of affixing them to the cockpit decking.
The outer struts I found a bit short in height, so added some plastic sheet to the ends.  Once the glue dried, the ends are sanded flush with the original part.  All ends also had some brass pins added to better lock into pre-drilled holes.
... and finally grey primer is on.   Upper wing is just a test fit for photo purposes.  Should mention the resin MG's (Gaspatch product), were not a  simple drop fit.  The undersides had to be carved,  as well as the framework they sit on inside the cockpit.  Compared to the kit's weapons, Eduard had them undersized.
regards,
Jack
« Last Edit: June 08, 2018, 02:03:52 AM by Halus »
« Reply #49 on: June 07, 2018, 03:09:49 PM »
Excellent update, it really looks a bigger scale.
« Reply #50 on: June 08, 2018, 12:34:24 AM »
Excellent results showing your work was worthwhile! Looking forward to seeing some color...even if it is PC10 or 12  ;D
Offline Halus
« Reply #51 on: June 08, 2018, 01:59:03 AM »
Thank you Giuseppe and RAGIII.
Yes, it will be a variation of PC10.
According to the late Dan San Abbott - "The RNAS were not permitted to use PC10, and RFC patent and they developed their own color which was a greenish shade of olive drab."
regards,
Jack
« Reply #52 on: June 08, 2018, 03:35:26 PM »
That do look good!
Offline Halus
« Reply #53 on: June 10, 2018, 07:35:23 AM »
Tank you GazzaS.
No colour on yet.  Sanded some rough spots and sprayed the areas with primer one final time.   I hope to utilize the grey as part of the shading underneath the main paint.
regards,
Jack
