Author Topic: 1/48 Eduard Weekend Edition Fokker Dr.1  (Read 5087 times)
Offline TobyCoulson
« on: January 03, 2018, 05:43:49 AM »
Next up is the Eduard Fokker Dr.1
It's the weekend edition but I have acquired the Eduard PE kit for the build. Also included are Aviattic streaked camouflage.
The markings will be for Deutsche Luftstreitkräfte (Imperial German Air Force 1916-1920) 564/17 (Lt. Werner Steinhauser).
Offline TobyCoulson
Re: 1/48 Eduard Weekend Edition Fokker Dr.1
« Reply #1 on: January 03, 2018, 11:45:28 PM »
Made a start with the engine using Vallejo MA Aluminium, Brass, umber wash and Mr Hobby burnt iron
Will give it a light coat of gloss varnish before installation to bring out some lustre.
Offline Softscience
« Reply #2 on: January 04, 2018, 03:45:35 AM »
Aha! Now I've got an expert to imitate  ;D
« Reply #3 on: January 04, 2018, 09:46:08 AM »
Really great looking engine! Nice start on one of my favorite aircraft and schemes.
Offline Iancshippee
« Reply #4 on: January 04, 2018, 10:24:03 AM »
Great start, Toby! That engine looks excellent.
« Reply #5 on: January 04, 2018, 11:09:54 AM »
Nice start Toby, looking forward to your progress.
Offline TobyCoulson
« Reply #6 on: January 08, 2018, 07:15:47 AM »
Started on the interior. It's so nice to have a kit where all the parts fit where they're supposed to.
I have another 4 in the stash. I may spend the rest of my life making little Fokkers.  ;D
Offline Softscience
« Reply #7 on: January 08, 2018, 01:43:16 PM »
Word of warning. Make sure the bar that goes across the center, just in front of the control column, is securely attached.
I didn't do that, and now have a major pain trying to reattach it through the tiny cockpit opening.
« Reply #8 on: January 08, 2018, 04:30:07 PM »
Very nice work,Toby. Looks as if there will be a stunning Dr.1 in your showcase.
bye,
Offline TobyCoulson
« Reply #9 on: January 08, 2018, 11:55:34 PM »
Now for the joining of two halves.
Softscience, thanks for your advice. I will make sure everything is in place before I marry up the fuselage.
« Reply #10 on: January 09, 2018, 03:46:09 AM »
Continuing to look excellent. I look forward to the next update.
« Reply #11 on: January 09, 2018, 05:37:21 AM »
Great start! Steinhauser's is the prettiest of all the Jasta 11 tripes in my opinion.
Best regards
Borsos
Offline TobyCoulson
« Reply #12 on: January 15, 2018, 08:34:07 PM »
I decided to get the Aviattic bespoke decals rather than make up my own from their streaked camouflage decals.
I tried applying the starboard decal without removing the forward outlet with dire results. "Repairs" effected but a mistake I won't make again. I will try and tidy up the repair before the end.
So I cut the port one off, applied the decal and then reattached the outlet
I did attach the top decal but my initial fitting of the side decals left a gap so I've had to make up a new one from the streaked camouflage set I already had from Aviattic. Still not correct but most will be hidden by the triangle decals. In future builds when using these bespoke decals I'll make sure there is no gap. One way will be sanding away about a .5 mm from the fuselage halves to ensure the top decal is big to cover with no gaps.
« Reply #13 on: January 16, 2018, 06:30:39 AM »
Moving along nicely !
Offline jeroen_R90S
« Reply #14 on: January 16, 2018, 06:56:34 AM »
Seems like a fiddly job... probably one of the reasons I'll do my 1/32 with oils... decals and me, just can't seem to get along.
Persistance will pay off, though!
