Author Topic: Fixing warped resin parts  (Read 2371 times)
Offline cduckworth
    • My WW1 Models
« on: December 13, 2017, 11:36:40 AM »
The W.12 is put back on the shelf until I get some replacement naval hexes.  So I pulled the Planet Rumpler C.I out of storage and decided to tackled it.  The fuselages halves look like two bananas.  They are both warped to the extent I don't want to add the interior until I get them somewhat in line.  I've placed two clamps on line them up and have them sitting in hot water from the tap.  Hope this helps but wondering if the wife's hair dryer might be a better choice.
Any suggestions from those that that had to deal with this below....
Charlie
"Look alive. Here comes a buzzard."  Pogo
Re: Fixing warped resin parts
« Reply #1 on: December 13, 2017, 01:25:26 PM »
Charlie, I built the Planet Rumpler and had the same issue.  I boiled some water,  used a pair of tongs to dip the parts in the water, then quickly placed them, mating surface down, on a smooth, flat, cool surface, like glass or a counter top or a piece of tile.  Worked like a charm.  No clamping needed.
Good Luck!
Offline cduckworth
    • My WW1 Models
« Reply #2 on: December 14, 2017, 06:34:02 AM »
Thanks for the suggestion, the boiling water and flat surface did the trick.    Did you replace the resin wing struts with another material?
« Reply #3 on: December 17, 2017, 03:46:51 PM »
I can't remember for sure, Charlie, but I think I used Strutz, a brass product from Aeroclub, sadly no longer available.  I can't remember what the kit struts looked like, but I think they were a little thinner than these.
I'm glad the warpage is gone from your fuselage.  I look forward to seeing your build log.
