Author Topic: Norman Thompson NT.2B (1/72, Lukgraph)  (Read 8725 times)
Offline TobyCoulson
Re: Norman Thompson NT.2B (1/72, Lukgraph)
« Reply #15 on: December 13, 2017, 04:57:37 PM »
Outstanding work on a topic I've not seen before. Bravo
« Reply #16 on: December 13, 2017, 10:23:58 PM »
Wow, very good work, it will be a stunner. Great if it is done in 32nd but in 1:72 it's just outstanding.
Bye,
Agree with Manni.
« Reply #17 on: December 13, 2017, 11:00:13 PM »
Przemol,
    The detail on that interior belies the small scale; magnificent work! This is going to be a real beauty once "dressed up" and completed with lots of wood finish!
« Reply #18 on: December 14, 2017, 12:32:29 AM »
Another stunning little interior Prze, beautiful work.
Online RAGIII
« Reply #19 on: December 14, 2017, 02:20:33 AM »
Your work on the interior is exceptional as always! Beautiful!
« Reply #20 on: December 14, 2017, 04:49:27 AM »
Agree with my Amigo, regardless of scale always superb !!
« Reply #21 on: December 16, 2017, 01:54:00 AM »
Never heard about this plane, it's interesting (as usual) to follow your build.
Antonio
« Reply #22 on: December 16, 2017, 03:29:15 AM »
Wow, that little interior is just fantastic! The colors looking great.
Offline Syd Solo
« Reply #23 on: December 21, 2017, 07:37:29 PM »
Prze
Your usual brilliant work in this classic scale. Always impressive, mate.
Syd
Offline jeroen_R90S
« Reply #24 on: December 23, 2017, 05:23:28 AM »
I saw some Lukgraph models at our last IPMS National show at a vendor but was not allowed a look into the box of the EE Cork, which I really liked. I was curious as to the quality, but if it is comparable to this one it's quite good it seems, as is your work on it! :)
My last experience with resin was with a Lone Star models update set to convert an P-3C Orion into an EP-3B and that was so horrible, I had to use a pack of sandpaper and half a roll of Milliput to get that both cleaned up and installed.
Since that experience I've been put off resin when it comes to  buying resin kits or update sets unseen., so I did not get the Cork... (what's in a name for a flying boat!)
Jeroen
« Reply #25 on: December 29, 2017, 09:13:59 AM »
Thank you, everybody, for your encouraging words.
Jeroen, as far as I know, the Lukgraph kits quality is fine all around their range. I heard their larger kits maybe even better than the smaller ones. Anyway, I am sure you could ask for photos of the box contents at the producer, pity though, you could not see the box contents in the flesh.
Well, we all know rein kits are not a shake and bake type, the choice should depend on one's experience with this type of material and resolution to build usually unusual models. As is the case with this one.
The recent modelling sessions were devoted to filling the numerous air bubbles at the hull bottom. The new ones tended to emerge when sanding the previous patches. Finally, after three or four attempts, when testing with an arbitrary colour airbrushed I found the acceptable surface. Then I also added the stabilisers - fit was not bad but not good enough to eliminate filling and sanding. Now the hull is ready for airbrushing. However, I am still thinking how to make the distinction between the separate side planks - there are six of them in the deepest hull section. I may still go for delicate scribing of planks borders and wash. Or just airbrushing with some fine shading. Stay tuned...
« Reply #26 on: December 29, 2017, 09:18:37 AM »
Very nicely done so far Przemol, the internal detail looks really good, hard to believe it is a 1:72 scale kit, looking forward to more updates.
