Author Topic: Eduard Pfalz D-IIIa Weekend Edition  (Read 7357 times)
Offline boggie
Re: Eduard Pfalz D-IIIa Weekend Edition
« Reply #15 on: November 16, 2017, 10:04:07 AM »
G'day Chuck.
The rectangular raised surface on the port side of the top wing, portraying the top of the gravity fuel tank, is a kit error.
The protruding fuel cap is correct, but the gravity fuel tank is located under the ply centre skin.
Archival pix on the WNW site and in various Pfalz publications, show the wing surface adjacent to the wing
radiator to have a smooth surface, except for the filling point. I hope this info is helpful.
cheers   :)
Offline skeeterbuck
« Reply #16 on: November 17, 2017, 09:42:44 PM »
G'day Chuck.
cheers   :)
Wow, good one boggie, I never really noticed that.  :o I will have to make the correction in this next build. I think it may have been a case of "I couldn't see the forest cause of the trees." LOL!  ;)
Chuck
Offline boggie
« Reply #17 on: November 18, 2017, 11:23:26 AM »
G'day Chuck.  :)
I don't think you missed the forest at all. Most of us who have built a Pfalz DIII/a have just accepted the inaccuracy as correct.
When WNW released their DIIIa the question was asked, hey, did they get it wrong? There appears to be a few wing panels missing.
The following is a reply to Stephen Lawson of Aeroscale, by Richard Alexander, posted on the Aerodrome forum in Jan 2011.
I think you will find it of interest.
Stephen posted: In doing my kit review I had several discussions with Mr. Richard Alexander of WNW and I mentioned to him the issue here and though I am addressing it in my review he sent along this bit of information. I'll post it here before things go too far off base.
"Hi Stephen,
Interesting thread and I suppose not entirely unexpected. I'm sure you
probably know much of this anyway, but just to clarify our position on the
'missing wing panels' and answer a few of the questions being asked. . .
The wing fuel tank was on the inside of the Pfalz D.III and D.IIIa upper
wing. It was covered with the ply that skinned the center section and was
not visible on the upper surface of the wing (other than the faired in
filler tube/cap protruding through the wing).
I don't know exactly when the myth of it being a detail visible on the
outside of the wing began, but it appears to have been started by an early
draftsman misinterpreting the Pfalz D.III drawings in the Flight capture
report. In the original Flight report the internal wing tank was drawn
with dotted lines to indicate that it was an internal detail.
Additionally the wing tank is not visible in any photo of a Pfalz D.III or
D.IIIa that I have ever seen (other than certain crash photos where it has
fallen out of course).
The lower wing root panel which is 'missing' is a reinforced walk strip
presumably intended for a mechanic to stand on while he makes final engine
etc adjustments before flight. These don't appear to be on every airframe
and when they are, they're not a standard size. It was not possible to
confirm if these were on any of our colour schemes, let alone what shape
they would be if they were. A pretty simple thing to add if you feel your
model needs it (check the reference photos in our instructions and on the
website for the shapes and sizes).
The 2 smaller hatches on the upper surface of both lower wings are covers
for the point where the aileron control cables are connected to the cables
coming from the control column. These hatches are hinged at the front and
held down by 2 turn buttons at the rear.
The wing attachment lugs are covered by the 4 smaller hatches under the
lower wing. These were also hinged at the front and held down (up?) by a
single turn button.
I hope this clears things up a little.
Richard"
Stephen added that the first time this myth was moulded into plastic was with the Aurora 1:48 kit!  ???
I would like to repeat that your Pfalz is excellent indeed and I very much look forward to viewing your next.  :)
Offline skeeterbuck
« Reply #18 on: November 19, 2017, 07:49:34 AM »
I have been working on the upper wing and have filed off the fuel tank completely flush with the surface of the surrounding area. I now only need to scratch the filler cap to complete the conversion. I just need to spray some primer on the area first to check my work. I don't want the removal work to show on the finished wing.  :)
Offline jeff shreve
« Reply #19 on: November 20, 2017, 03:54:51 AM »
Very nice work Chuck! I'm working on the other scheme from the same kit - won't look as nice as yours though.
Offline TobyCoulson
« Reply #20 on: November 21, 2017, 11:40:59 AM »
Very good. I do like the weathering on the top wing.
« Reply #21 on: November 21, 2017, 01:26:03 PM »
Very nicely done, I especially like the treatment of the overpainted crosses. I too shall make a note of the fuel tank issue, for when I build one....
Offline skeeterbuck
« Reply #22 on: November 22, 2017, 02:11:52 AM »
Ian,
I like to take credit for the overpainted effect, but it goes to Eduard as the decals are already printed like that.  ;)
Offline skeeterbuck
« Reply #23 on: November 23, 2017, 11:50:01 PM »
Some pics of the new modified upper wing with the removal for the fuel tank and scratch built filler cap and flaring. I also added the Venturi tube to the header tank on the radiator. Feedback requested.  :) Chuck
