Author Topic: WNW FE2B 6341  (Read 30323 times)
Re: WNW FE2B 6341
« Reply #60 on: March 03, 2013, 05:30:25 AM »
  Andrew,
I do appreciate the work you've done rigging with RB RAF Wires. I'm afraid they'd be far too fiddy for me to pull off correctly. As others have mentioned they do certainly look great. Keep up your outstanding progress my friend.
Offline AndrewS
Re: WNW FE2B 6341
« Reply #61 on: March 05, 2013, 07:17:31 PM »
Some pictures of the closed fuselage (the colurs of the pictures are a little bit off... I should work with manual settings of the white balance the next time ....)
The tail boom is also going on
And finally a picture of the propeller. It still needs some retouches, a gloss coat and the hub must be painted
Now I have to paint the fuselage, install the engine and then I can start the wings assembly.
Offline michael
Re: WNW FE2B 6341
« Reply #62 on: March 06, 2013, 01:10:38 AM »
Top quality there Andrew in particlar i like the job you have done on the prop
michael
Offline AndrewS
Re: WNW FE2B 6341
« Reply #63 on: March 11, 2013, 04:39:14 AM »
Hi!
I've painted the fuselage.
I've decided to paint the black and white stripe on the nose,
the wingnut decal is very good but I it's too perfect .
The masking was easy and I think that the final look is better.
I've started the weathering but there's some little work to do.
(the engine and the wings are not glued yet, I put them in place only for the pictures).
I'll post some updates during the week.
Offline Pete Nottingham
Re: WNW FE2B 6341
« Reply #64 on: March 12, 2013, 07:51:43 AM »
Lovely job there Andrew.
Pete.
Re: WNW FE2B 6341
« Reply #65 on: March 12, 2013, 10:27:52 AM »
Very fine work, Andrew.  The painted stripe does look better.
Re: WNW FE2B 6341
« Reply #66 on: March 12, 2013, 01:09:24 PM »
   Andrew,
Excellent work my friend. Eagerly awaiting the next update.
Re: WNW FE2B 6341
« Reply #67 on: March 12, 2013, 07:07:05 PM »
Very well done from the interior to the exterior. I really like your engine and the wood grain on the engine mounts.
Offline Andi Little
Re: WNW FE2B 6341
« Reply #68 on: March 13, 2013, 03:53:56 AM »
Dear God!! ................ I'm a newbie: and I now feel so bliddy inadequate! An absolutely steaming good job.
Marvellous ................
KBO ............. Andi.
Re: WNW FE2B 6341
« Reply #69 on: March 13, 2013, 06:41:39 AM »
Hi Andi;
We all feel like this when we see some of the builds on the forum, but we look and learn and hopefully we incorporate some of the good points in our own builds and that way we improve ourselves, but if you are not sure just ask, all the guys on here will help with their methods and that way help us all improve.
Pete.
Offline AndrewS
Re: WNW FE2B 6341
« Reply #70 on: March 13, 2013, 05:34:53 PM »
Don't worry!
It's easier than it looks.. this is just my second WWI model since I've restarted modelling  ;)
Don't start thinking that you can't do something: just try and you'll be surprised  :D
If you have any question just ask
Re: WNW FE2B 6341
« Reply #71 on: March 13, 2013, 10:34:49 PM »
You have sand my friend, to tackle this kit for just your second WWI model. And with such spectacular results to boot. It's looking spectacular.
Re: WNW FE2B 6341
« Reply #72 on: March 14, 2013, 10:18:20 PM »
Hello Andi:  I have to echo the sentiments of the others here.  Don't feel inadequate, just feel part of something and go for it.  Lots of good build logs here to reference and lots of helpful folks.
Andrew S.  Outstanding work to date.  As Chris Mentioned, lots of sand to tackle this one for only your second WWI kit, but; why not.
Re: WNW FE2B 6341
« Reply #73 on: March 15, 2013, 03:45:57 AM »
Nice work - amazing for a re entry into modelling subject!!
Offline AndrewS
Re: WNW FE2B 6341
« Reply #74 on: March 19, 2013, 08:11:47 PM »
Hi!
Allright, the madness is going on  ::)
I've attached the engine to the fuselage and added some wires. Now I've only to weather a little bit the carburetors and I'll be ready to attach the wings.
I've built a couple of turnbuckles... they are very small!!!
