Author Topic: [AZ MODELS] Ansaldo SVA.5+extra  (Read 7953 times)
Stephane
Re: [AZ MODELS] Ansaldo SVA.5+extra
« Reply #15 on: May 12, 2018, 04:41:59 AM »
thank you! No, my bench is dirty allready...
the floats are done. I will try this weekend to make the attachments.
take care.
« Reply #16 on: May 12, 2018, 06:22:34 AM »
The fuselage looks gorgeous as does the lower wing. Looking forward to seeing the new update.
« Reply #17 on: May 12, 2018, 02:02:54 PM »
Very nice start on a hard task indeed, proceeding very well.
« Reply #18 on: May 12, 2018, 03:42:31 PM »
I agree with my friends above
The scratch built floats are perfect!
Antonio
Online NigelR
« Reply #19 on: May 13, 2018, 05:41:56 PM »
That is looking pretty good already, and very nice work on the floats.
Stephane
« Reply #20 on: May 22, 2018, 01:35:55 AM »
Hi and many thanks for your support,
As I found only one profil picture of this ISVA with Sopwith type floats, even the same on the datafiles book, my work is not closed to reality.
So I used some knowledge in carpentry to find the real size of the 6 strong legs beetween fuselage and floats.
this done, I cut thin brass tube and insert for tenon inside. A little bit disappointed, the result is far away from the picture, I' m too high, but everything fit perfectly ;D
So I can' t resist to show you proudly result of monday' s progress:
Next step soon, I have to make it at the right size first!
