Author Topic: Turnbuckles: Advice needed  (Read 14048 times)
Offline stefanbuss
« on: September 24, 2012, 04:53:02 PM »
Friends,
I have no problem in making turnbuckles, using the proven method of brass-rods cut to size, combined with fishing-line for the cables.
But: What is a useable way of representing the splicing on the cables? Using the same brass-rod (that is already of tiny 0,5mm diameter) seems to be oversize. The stuff that Bertl used on his Albatros and Pfalz builds looks good but is waaay to expensive for me.
What is your method?
Stefan
Offline kornbeef
Re: Turnbuckles: Advice needed
« Reply #1 on: September 25, 2012, 03:12:48 PM »
Stefan, Hi.
I've experimented using nothing other than the line ( I use Nylon mending thread) and Thin Cyano. Looping the cable through an eyelet spinnin it tight and applying Cyano to the twisted section while under tension. then again when set coat it again.
Yes it's fiddly, yes theres a high fail rate but I like the results when it works. (no spoilt brass tube either is a minor bonus.
Not the clearest of shots unfortunately. Paint over them to represent the fabric wrap often seen .
I've actually taken to doing complete cable assemblies off the aircraft and adjusting & fixing them later. This however comes unstuck when the mounting point is hard to access.
Hope this helps
Keith
« Reply #2 on: September 25, 2012, 04:13:30 PM »
Wow, Keith!  That is truly stunning.  Excellent cable connections, but mainly a brilliant model.  What kit is that?
« Reply #3 on: September 25, 2012, 07:58:03 PM »
Brilliant Rumpler, Keith. The top photo looks 100% real.  As in "why is he showing us a picture of an actual plane?"
Offline kornbeef
« Reply #4 on: September 26, 2012, 03:05:32 AM »
Hi guys thanks, Bud It's WNW's early Rumpler, a really lovely kit.
Offline Dal Gavan
« Reply #5 on: October 06, 2012, 05:06:39 PM »
Keith, thanks for showing us your method of doing the rigging eyes.  I've been trying to work out how to do what you've done so well- and I've redone all the rigging on my build.
Can we persuade you to put up a few more photo's of your Rumpler, please?
Dal.
« Reply #6 on: October 06, 2012, 10:29:40 PM »
Dal.
+1, drool.
« Reply #7 on: October 07, 2012, 01:49:10 AM »
Dal.
+2, drool.  :)
Offline kornbeef
« Reply #8 on: October 08, 2012, 12:35:22 AM »
okies, I'll post a few in the completed section
K
Offline petrov27
« Reply #9 on: October 08, 2012, 07:06:06 AM »
Just curious - what does Bertl use? I went through the excellent worn out Pfalz build thread but did not find where he named what he used...
Thanks!
-Patrick
« Reply #10 on: October 08, 2012, 11:30:12 PM »
Bertl,
 Uses the brass tube and handmade eyelet method - he will need to confirm this, of course  ;)
BVB
Offline petrov27
« Reply #11 on: October 09, 2012, 10:52:58 AM »
Bertl,
Yep, I was thinking of the way he closes off the wire loop that fastens the running wire to the buckle - the red/brown bit in the pic below. I was thinking maybe some sort of micro shrink tube? I like how it is a smaller diameter than the brass tube (seems more like real)
-Patrick
