Author Topic: WnW 1/32 DFW C.V (late)  (Read 6532 times)
Re: WnW 1/32 DFW C.V (late)
« Reply #15 on: January 16, 2017, 04:48:20 PM »
Magnificent, Gary. Pure joy to behold this model!
« Reply #16 on: January 16, 2017, 08:20:06 PM »
All of the above... and some!
Well done!
vB
« Reply #17 on: January 17, 2017, 07:35:04 AM »
All the above says it all !!!!
« Reply #18 on: January 17, 2017, 09:24:23 AM »
Can't add anything that isn't said yet: truly amazing!
Borsos
Offline steveb
« Reply #19 on: January 17, 2017, 01:19:18 PM »
Such magnificent work & photography! I love it!
« Reply #20 on: January 17, 2017, 01:21:45 PM »
I must say I'm humbled by everyone's response - glad you all like the model.
Paul - your Model Cellar figures are second to none. I've met Mike Good a couple of times and he's a world class sculptor. I hope to find a few more of these types when I go to Omaha NB next summer.
Lance - if I can make it to Nanton this year I will, but promise me you'll be there with all of your latest builds! Your projects are world class, and I look forward to seeing them in person. Too bad more of us Albertans don't make an effort to get to these shows to see the work in person...
Eindecker - The effect I was trying to get on the upper surfaces of the wing was an indication of "structure" in the paintwork. Although the finish is streaked, I still feel the need is there to indicate the skeletal nature of the wings. Like you say - the linen would give a "highlight" to the raised bits, and I was trying to capture that. Same with the underside - which in daylight seems "darker", so I tried to emulate shadow underneath. I compromised the lower side by not adding all of the rib sections, but you have to consider effort vs. what is seen (?). Always a moral dilemma! I also did a bit on the tail, because if don't, it seems a bit more flat and boring.
Again - thanks to everyone who took the time to write a comment on my model, each one is truly appreciated  :)
Offline boggie
« Reply #21 on: January 17, 2017, 08:31:46 PM »
Extraordinary Gary!
Your build has been an education and also fun to follow.
I wonder what that aircraft looked like when first delivered to the front?
cheers  :)
« Reply #22 on: January 22, 2017, 06:43:22 AM »
That is a great build, Gary! It is perfectly executed with some absolutely beautiful weathering effects... a very enjoyable build to follow! Regards, Marc
