Author Topic: LVG C.VI, Pegasus 1/72  (Read 41577 times)
Re: LVG C.VI, Pegasus 1/72
« Reply #90 on: May 05, 2017, 10:16:11 AM »
This is turning out to be a very enjoyable build to follow , coming along very well  :)
« Last Edit: May 06, 2017, 09:37:59 AM by Terri »
« Reply #91 on: May 05, 2017, 11:15:50 AM »
Coming along quite nicely, paint and details are first class.  :D
« Reply #92 on: May 06, 2017, 04:48:17 AM »
Ditto the above comments, excellent work in 1/72.
« Reply #93 on: May 07, 2017, 05:19:44 AM »
I am looking forward to seeing the results from all of the pre shading!
Offline Wolf
« Reply #94 on: May 10, 2017, 01:22:00 AM »
Normaly I do the wood effects with oil paints. This time I deceided to go an other way. MAin reason was that I do not want the wait for the drying time which is usualy neccessary for oil paints.
In the first step, I enhanced the preshading by the use of blank paint along the panel lines.
In the second step, I softened the black and enhanced the shading by the use of dark brown.
The last step of the preshading is used to further soften the transistions between the paints und to give the surface a more patchy appearance. This time a mid brown was used
This is now the base for coming pale layers of paints which hopefully will blend all layers together and will leave a pale but subtle patch surface
« Last Edit: December 01, 2017, 12:58:21 AM by Wolf »
Online lone modeller
« Reply #95 on: May 10, 2017, 02:41:37 AM »
Thanks for showing us this technique. I for one will be following developments with interest.
« Reply #96 on: May 10, 2017, 04:05:53 AM »
 Wolf,
Another fantastic update my friend. Thank you for this thread, it just gets better with each update. Well Done !
Highest Regards
Stephane
« Reply #97 on: May 10, 2017, 04:36:44 AM »
Very very nice and impressive work on this scale.
I' m watching with eyes wide open.
Stephane
« Reply #98 on: May 10, 2017, 04:59:23 AM »
Looking really good, looking forward to your spraying to see the full effect.
Offline steveb
« Reply #99 on: May 12, 2017, 12:08:53 PM »
Yes, I am also awaiting the results! Looks great so far. Is that Parafilm masking on the tail?
Offline Wolf
« Reply #100 on: May 13, 2017, 12:36:46 AM »
Thank you, gentlemen.
Yes Steve, that's parafilm. Regarding the next steps, I will use a similar technic you used on your Allbatros.
In the next step I sprayed thin layers of Gunze "Sail" over the whole fuselage until the preshading vanished and only left some darker subtle shadows under the sail color
In a second step, I additionally sprayed a mixture of 50/50 flesh/white to further brighten up the fuselage in some areas.
(This time, as variety, I will show the underside
« Last Edit: December 01, 2017, 01:00:15 AM by Wolf »
« Reply #101 on: May 13, 2017, 02:34:37 AM »
Thanks for sharing your technique, it's looking really good so far!
Offline Wolf
« Reply #102 on: May 15, 2017, 08:57:14 PM »
I enhanced several panels/areas by spraying a cloudy layer of mid brown.
« Last Edit: December 01, 2017, 01:00:46 AM by Wolf »
« Reply #103 on: May 15, 2017, 11:17:12 PM »
Coming along nicely. The layers of coverage should give an excellent effect!
Offline Wolf
« Reply #104 on: May 17, 2017, 11:05:18 PM »
In the step next to last, irregular patterns were painted on the fuselage, by using a damp brush which was loaded with pastels
« Last Edit: December 01, 2017, 01:02:55 AM by Wolf »
