Author Topic: Italian N-17 1/48  (Read 13199 times)
Re: Italian N-17 1/48
« Reply #15 on: November 14, 2016, 02:24:19 AM »
Those cockpit interior shots look really good, This one is shaping up nicely - the paint finish on the cowling is super.
« Reply #16 on: November 14, 2016, 03:30:00 AM »
Great start Terri! Your interior looks awesome!
« Reply #17 on: November 14, 2016, 03:49:24 AM »
Beautiful start Terri!
« Reply #18 on: November 14, 2016, 04:05:42 AM »
Nice detail work Terri, and I really like the silver on the cowling. Is it the Vallejo White Aluminum you mentioned earlier?
« Reply #19 on: November 14, 2016, 05:25:59 AM »
Thank-you guys for the kind comments . Halves are glued together and then it's putty and sanding time ...
Lance , yes and no . Yes I did use Vallejo's new metal cote range and I'm sad to say that no it's not the white alum . It is their polished alum spray right over bare plastic .
« Reply #20 on: November 14, 2016, 04:46:19 PM »
Good start, Terri.
I will follow this build.
« Reply #21 on: November 15, 2016, 04:32:57 AM »
 Terri,
As always outstanding progress my old friend. Very impressive work on her interior and beautifully painted cowl. I believe I need to take a serious look at these new Vallejo metal cote line. Hopefully I can lay them down better than the Alclad paints. Keep up the high standards Terri.
« Reply #22 on: November 15, 2016, 11:05:45 AM »
Thanks Manni , hope you enjoy the build  :)
Gregory , they are very easy to use , as you can see the paint on the cowl . It has a more lustrous shine to it when their gloss black primer is used . I haven't tried any other brand of acrylic gloss black as the primer , but I will give Tamiya black a try and see what happens .
Have a look on their web site they have a bit of info on the metal cote and other products . I just started using Vallejo Model Air and I love it ! Takes a bit longer to dry then what Tamiya . But Vallejo Metal cote dries very fast . You can mask in ten minutes , but they do recommend waiting 24 hours for it to cure .
« Reply #23 on: November 15, 2016, 03:37:51 PM »
Very nice start on the cockpit, it looks clean and sharp in detail. Just pretty!
Borsos
« Reply #24 on: November 16, 2016, 12:27:31 AM »
Stunning work, Terri! There is some very neat and detailed work in the cockpit! The Rudder looks lovely too... I'm going to enjoy this build! Regards, Marc
Offline Ian from Doncaster
« Reply #25 on: November 16, 2016, 02:05:08 AM »
Looking great Terri :)
I think is the same model I made about 3 and a 1/2 years ago..  I rushed mine though, trying to take the "weekend" theme literally!
« Reply #26 on: November 16, 2016, 10:10:40 AM »
Shaping up beautifully, T!  Your work in the pit is outstanding!
« Reply #27 on: November 16, 2016, 11:49:01 AM »
Dittos from Amigo #3
« Reply #28 on: November 16, 2016, 05:48:27 PM »
Some fine modelling, Terri. Looking forward to see more.
« Reply #29 on: November 17, 2016, 12:07:11 PM »
I have made progress . Fuselage halves a joined and puttying and sanding done . There is detail needed to dress up a few areas before the primer . Lower wing has been test fitted and I got a much better fit this time around on this build compared to the last one I did . Will have some pic's up this weekend .
Thanks guys for following along so far . :)
