Author Topic: Eduard's Tripe//1:48  (Read 5993 times)
Offline KrzysiekK
Re: Eduard's Tripe//1:48
« Reply #15 on: September 05, 2016, 07:43:57 PM »
Hello,
not much to show despite adjusting piston and some sand paper work done
I have also added inspection windows
regards
K
« Reply #16 on: September 06, 2016, 01:33:00 AM »
You have made great progress. The open rear fuselage and inspection panels on the wings came out great!
Offline xmald
« Reply #17 on: September 06, 2016, 01:44:20 AM »
As always I`m late... Both the cockpit and the engine are looking very good. The PE in the Profi version of the kit isn` t that impressive at all, and I like your work much. Is it THIS engine or have you used some other one??
Best regards
Filip
Offline KrzysiekK
« Reply #18 on: September 12, 2016, 07:41:45 PM »
Hi,
No Filip it is not THAT engine:) this one is from the box.
Here comes the painting
I have implemented first layer just to emphasize the wood structure of the plane. It is not well visible but the cockpit top area was painted brown as the base
then put the second layer –little darker than previous once
at last used some filters to be more reminiscent of real effect
now have to handle the bottom
regards
K
« Reply #19 on: September 14, 2016, 04:04:55 PM »
excellent thus far
« Reply #20 on: September 14, 2016, 04:09:44 PM »
Superb work to date K, I especially like the interior and the instrument panel.
Offline Dick dastardly
« Reply #21 on: September 14, 2016, 10:12:00 PM »
really great work,
Muttley, Do Something!!!!!!!!!!!!!  Drat and Double Drat
Offline KrzysiekK
« Reply #22 on: September 22, 2016, 12:48:08 AM »
Hi,
Being out with modelling for some time due my kids illnesses, which started together with beginning of school time, did some little steps forward specially with painting.
I put vallejo silver layer then used Uschi powders and decided to make more reminiscent to those peculiar rude cowling appearance visible on some pics available. I took the piece of fabric from old table cloth and did several finger pushes.
I am not quite sure this bottom part but it was done in the line with Eduard’s manual. Does anybody have any idea if the metal parts should be implemented till the end of bottom wings end, pls let me know.
did some shading on the wings as well
the engine is done
regards
K
Offline Adam
« Reply #23 on: September 23, 2016, 09:55:36 PM »
It looks very good.
Adam.
« Reply #24 on: September 26, 2016, 05:15:30 AM »
Excellent work on the painting/shading and the engine/ cowling!
Offline xmald
« Reply #25 on: September 26, 2016, 06:24:15 AM »
The cowling is superb! The idea is pretty simple but almost genious ;)
Great work so far!
Best regards
Filip
« Reply #26 on: September 26, 2016, 02:07:20 PM »
excellent work k
Offline KrzysiekK
« Reply #27 on: September 29, 2016, 08:23:25 PM »
I suspect it ends well before the trailing edge of the wings.
Yes, all Tripes I have seen on the web have likewise. I thought that because of skis I could been little different
Let’s move on with this assembly. The undercarriage is done and positioned to fix the holes
Somebody asked for the skis, so finally I managed them
regards
K
« Last Edit: September 29, 2016, 09:06:30 PM by KrzysiekK »
Offline xmald
« Reply #28 on: September 30, 2016, 04:47:59 AM »
The skis are looking very good! You`re not far from completing the kit now.
Best regards
Filip
« Reply #29 on: September 30, 2016, 10:31:40 AM »
She is shaping up wonderful so far .  :)
