Author Topic: My first WW1 build - WNW Hansa-Brandenburg W.29  (Read 26437 times)
Re: My first WW1 build - WNW Hansa-Brandenburg W.29
« Reply #75 on: October 18, 2016, 09:09:49 AM »
Wow, fantastic work.  Keep pushing, the end (of this aircraft) is near.
« Reply #76 on: October 18, 2016, 11:37:12 PM »
Looks great with the wings sitting in place! You are getting close now to the finish line!
Offline petero
« Reply #77 on: October 29, 2016, 06:36:48 AM »
I've attached the floats and tightened the float rigging.
The wings' lozenge decals have turned out to be a problem.  By the time I had finished doing shading along the ribs, there were many un-stuck areas, both along the ribs and in between.  It's only the wings; the ailerons, elevators, horizontal stabilizer and fuselage spine are fine.  One wing is affected worse than the other, even though I decaled them at the same time.  I've been pricking and slitting the delaminated spots, and using Gunze Mr. Mark Setter and Softer to help them adhere again.  I'm not sure if I'll be able to fix them well enough, so I've already contacted Dave about purchasing another sheet of lozenges.  It would be a huge effort to strip the decals and start over, but better that than worrying about them coming off sometime down the road.
Peter
« Reply #78 on: October 29, 2016, 08:53:04 AM »
Wow Peter, that is looking good.  Sorry to hear about the wings, but you are right, better now than latter.  Hang tough, your workmanship shows.
« Reply #79 on: October 31, 2016, 04:21:37 AM »
Looks terrific. I am alxo sorry to hear about the wing lozenge. I am sure you will get that sorted out soon!
Offline petero
« Reply #80 on: November 01, 2016, 04:25:43 AM »
I've managed to fix my decal delaminating problem.  It took a few hours of pricking and slicing problem spots and sticking them back down with Mr. Mark Setter.  Unlike most decal solutions, Setter contains an adhesive, so it not only helps the decal conform, but it actually sticks it to the surface.  There are still some spots that could look better, but I have no desire to strip the entire wings and start from scratch!  :o.  The final matte coat helps hide the nasty spots too.
The shading around the ribs didn't come out evenly from wing to wing, but that's okay.  I also gently airbrushed some thinned cross color over the crosses' ribs to tone down the effect there.
Peter
Offline petero
« Reply #81 on: November 01, 2016, 06:06:09 AM »
They look pretty good to my eye :)
Thanks!  That's because you're more than 3 feet away ;)
Did you receive my PM about the Z-M Ho 229 back when I mentioned it?  It doesn't show in my Sent items.
Peter
« Reply #82 on: November 01, 2016, 06:57:03 AM »
Everything looks fantastic, Peter.  This is going to be a very special W.29.
« Reply #83 on: November 01, 2016, 08:32:11 AM »
I agree with Bud!
Offline petero
« Reply #84 on: November 02, 2016, 08:51:33 AM »
Thanks, guys!
I'm almost there now.  The wings have been finished, and they and the elevators and rudder have been attached and rigged.
The clear flat on the wings' lozenge hides a multitude of sins  ;)
All that's left now are the outboard float struts, airspeed indicator (from GasPatch), prop, exhaust and beaching gear.  I'll use the straight-bladed Axial prop, since that's what the photo most closely resembles.
I'm quite pleased with my efforts so far... back in July when I started, I gave myself about a 50/50 chance of finishing it.  Now I have to finish it - it takes up my whole workbench!  I'm also considering getting a case for it, since it's too large to fit into any of my glass-front bookcases.
Peter
Offline petero
« Reply #85 on: November 10, 2016, 05:22:43 AM »
The last details are coming together now:
The exhaust is from the new engine's sprue.  The BarracudaCast exhaust looked more interesting to me, but I liked the finish on this one better.
The anemometer is from GasPatch, with a new stanchion added.  The prop is the kit's Axial prop, since that's what the photos looked like.  Axial props tended to be a solid color.  The tips are Alclad Polished Brass, and the hubs are Steel.
Here is the short trestle that goes under the front of a float.  It was painted with Tamiya Deck Tan, then given washes of various gray and umber artist's acrylics.  The goal was to give it a fairly beat-up and neglected look.  The tall trestle and beaching dollies were similarly treated.
And finally, she's done!  I've just glued the beaching dollies to the floats with Gator's Grip glue.
Once those have dried, I'll take some good photos and start a thread in the completed models section.  Thanks for watching and commenting on the build - it was great fun, and I learned a lot of new techniques for the next one.
Peter
« Reply #86 on: November 10, 2016, 06:57:36 AM »
Outstanding results and a great build log! I am looking forward to the final photos
Offline petero
« Reply #87 on: November 12, 2016, 10:28:44 AM »
I've just posted some finished photos in the Completed Models forum: http://forum.ww1aircraftmodels.com/index.php?topic=7877.0
Thanks for following along, and for all your comments!
Peter
Offline pilot49
« Reply #88 on: August 08, 2018, 07:37:51 PM »
Hello my friend!!! You made a very nice work!! May I ask something about the rigging on floats; Where did you find this detail, because I have never seen any photo or any detail about this way of rigging on floats? I would appreciate if you send me any photo, because I have on the bench my W.29 Hansa and also have done a simple rigging on floats!! Thank you for your time!!
Nickolas
Offline petero
« Reply #89 on: August 08, 2018, 11:28:25 PM »
Thanks for your comments, Nickolas! There was a thread on this forum specifically about W.29 float rigging, which I referenced in the first post about the rigging. However, that post is no longer available, and I didn't copy the photos in that thread, so I no longer have the information.
The missing thread showed a few contemporary photos of the float rigging, with the circular attachment point and turnbuckles in the center.
Sorry I can't be more helpful.
Peter
