Author Topic: WNW Hansa-Brandenburg W.12  (Read 18881 times)
Offline eclarson
Re: WNW Hansa-Brandenburg W.12
« Reply #60 on: October 25, 2016, 11:00:15 AM »
It's trolley time!  While they may not be as interesting as the actual aircraft, I've been having fun the past few days painting and weathering the Hansa's beaching trolleys.  I had trouble deciding how I wanted them to look - painted gray as the W.12's instructions indicate, dark wood as shown in the W.29's instructions, or something altogether different.  I like the looks of the dark wood wheels seen on some models but most of the period photos I could find show these heavy wood wheels to be a light color.
After stumbling across an interesting video on weathered wood effects using Vallejo paints I decided to go that route with my trolley wheels.  The video is about 15 minutes but is well worth watching.  The subject happens to be a simple crate but as the presenter states, the technique can be used on any wood structure or item where this kind of appearance is desired.
This does not involve simulating a grain effect as we tend to do using artist oils or colored pencils but depends on layering of many different colors.
Here's the video...
http://www.plasticmodelsworld.com/node/1489
...and here are my trolleys with the wheels painted using the techniques described.
The rims are Mr Metal Color Iron and the hubs are Vallejo Air Metal Steel.
Eric
« Reply #61 on: October 25, 2016, 11:34:57 AM »
Eric,
   That's impressive, and very real looking, I like it! A fellow member gave me the Shapeways Dolly Wheels (with round wood spokes) and I think I will try this method of finishing them. Nice work!
Online Juan
« Reply #62 on: October 25, 2016, 08:29:45 PM »
Outstanding look on those trolleys.  Thank you for the link also.
« Reply #63 on: October 25, 2016, 11:01:08 PM »
Excellent results with the Valejo paint technique. I have a few crates I will have to try this out on.
« Reply #64 on: October 26, 2016, 06:15:04 AM »
Ooh! That Trolley looks superb! I must look at that link - the result looks great.... Marc
Offline eclarson
« Reply #65 on: October 28, 2016, 12:04:59 PM »
Nearing the finish line.  Just three "add-ons" remain to be completed and attached - the propeller, observer's gun, and a wing-mounted anemometer.
Eric
« Reply #66 on: October 28, 2016, 03:54:16 PM »
Great work, simply beautiful.
Online Juan
« Reply #67 on: October 28, 2016, 07:15:12 PM »
Super, just super.  The finish line is just ahead and you've done a wonderful job.  Look forward to the finish product.   :)
« Reply #68 on: October 28, 2016, 08:28:21 PM »
Looks Gorgeous! It has been a pleasure following your outstanding build!
Offline Adam
« Reply #69 on: October 28, 2016, 08:50:50 PM »
Amazing.  :)
Adam.
Offline eclarson
« Reply #70 on: November 01, 2016, 07:27:46 AM »
Thank you all again for those kind comments.
Just added a little exhaust staining across the upper wing and attached the prop.  The latter sure brings it to life!  Now I've got this sudden urge to yell "Contact!".   :)
Eric
« Reply #71 on: November 01, 2016, 08:20:50 AM »
That beautiful prop really sets it off!
Offline eclarson
« Reply #72 on: November 04, 2016, 12:40:32 PM »
Armed and dangerous.  Just finished assembling and mounting the observer's Parabellum.  This is the kit-provided gun with rolled photo-etch cooling jacket.
Eric
Offline eclarson
« Reply #73 on: November 07, 2016, 05:59:09 AM »
The final bit.  This particular W.12 had an anemometer air speed indicator fitted to the starboard wing so I added a GasPatch Models unit.  Photos of the real aircraft in the Windsock book show the indicator was painted light gray and was attached to the forward spar between the third and fourth ribs inboard from the wing strut.  Unfortunately the photos aren't clear or close enough to show how the indicator was mounted so I made an educated guess and slightly modified the part, replacing the mounting plate with a thicker piece of styrene which was drilled and a brass wire inserted which fit into a hole drilled in the wing.  A small styrene wedge was added as a reinforcing plate and to help keep the indicator level as it's on the sloped part of the wing's leading edge.  The indicator face was angled slightly to the rear so as to be easily viewed by the pilot.
Eric
Online Juan
« Reply #74 on: November 07, 2016, 06:10:18 AM »
Outstanding work Eric, the icing on the cake with that indicator.
